Previous in Forum: DVR problem   Next in Forum: VGA Cable Limitation
8 comments
Autodesk Inventor 11-Slots
07/12/2008 8:30 AM
If anyone uses Inventor 11 could you point me in the right direction? I'm trying to put slots on a part and can't seem to figure out how to do it. I thought it would be with the Hole option, but I can't find anything there. Specifically, I'm trying to make counterbored slots.
Any help is greatly appreciated. Thank you!
Hobbies - HAM Radio - New Member Engineering Fields - Mechanical Engineering - New Member United States - Member - New Member
Good Answers: 22
Re: Autodesk Inventor 11-Slots
07/12/2008 3:01 PM
I just checked the Help files in Inventor, and they say nothing about slots. You will probably have to sketch a profile of the inner bore and do a cut extrusion all the way through the part. The counterbore will need its own profile, but with a cut extrusion to the specified depth. For more than one slot, use rectangular patterns of the extrusions.
I don't know if the later versions of Inventor have a placed slot feature, but you might google them to see if they do. If you would like to see such a feature added to Inventor, the Autoesk User Group Internatonal surveys for "wish lists" for the Autodesk products, and depending on demand, Adesk implements them. Go to www.augi.com.
I wonder..... Would Schrödinger's cat play with a ball of string theory?
07/13/2008 7:12 AM
Thanks for your reply! That's actually what I ended up doing, but I will fill out that wish list.
07/13/2008 11:23 AM
re Autodesk Inventor 11 what is it? any on line sources for it?
thanks
'da ber
07/13/2008 6:41 PM
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=4246282
07/13/2008 11:31 PM
thanks for the info. i have disabled clients who ask some for some really off the wall type products to be made for them by members of a ontario canada based group called the innovators co-operative council of canada, i will pass that on to them.
again thanks muchly
'da ber
Popular Science - Weaponology - New Member United States - Member - New Member Engineering Fields - Manufacturing Engineering - New Member
07/14/2008 6:40 AM
TRY THIS , IVB MACRO
Jim C
http://www.kwikmcad.com/
07/14/2008 7:13 AM
Nice reply, Jim. Thank you for the website, that will come in handy!
Good Answers: 94
07/14/2008 9:24 AM
I've moved on from Inventor 11 but I think this command was available there, use the 'place feature' command from the browser, this gives a dialogue box from which you can select a number of features including straight & curved slots. Once you have created the slot, use the chamfer tool to add the countersink.
Register to Reply 8 comments
3Doug (1); Anonymous Poster (1); barfnagler (2); Jim C (1); mblouir (2); Nigh (1)
