I have many diesel welders 350 amp and up. The big 50 I bought new in 1985/6 did not have any bells and whistles. So I ordered everything that could be field installed from meters to Engin shut down protection and constent voltage. This is my smallest welder and the one I use the most because it is so much easyier to move around.About 15 years ago on rainy days the CV would not work so I would run CC and after it ran for an hour or so the CV would work. It has gotten worse over the years and quite last year. I did all of the voltage testing on it with my cell phone to millers diesel drive and me and my trustey VOM. It is either the board or the plug so as a last ditch effort to cure it I brought the board in the house and warmed it up then covered it with clear silicon on both sides hoping it would keep out any moisture. I screwed it back in place and attached the plug. I started it up and only had CC. By the way it is not one of the three toggle switches right over it. Winter was on me so I went to FL. and forgot about my problem. I just returned and started it up and it was working fine, I shut it down and restarted several times and it worked fine.I was a happy as one could be. I started it the next day and it only makes CC, I am at my wits end. Miller wants wayyy too much money for a board that only cost them $20 tops to build and if I buy it and it still does this I own the circuit board as soon as I open the bag.I know there are several places I can send the board out to be repaired but that was before I put the silicon on. Does any one know where there is a dead big 50 or 40 made between 1985 & 1988 that had a CV2 on it. The miller part # is123375 and every time I call them they up the price. I have bought five large millers in my lifetime and now that I am crippled up with out a big income I don`t seem to count any more. I would be careful if you are looking for a new machine on how hard parts are to get if you plan on keeping it for a long time. Thanks for listening and I hope to here back from someone with a answer.
