Previous in Forum: Voltage between hot & insulation of XLPE cable   Next in Forum: Survey on 120/240 volt North American Residential Services
9 comments
parallel connection
07/13/2008 10:13 AM
what are the conditions of parallel connection between two sources?
Location: Milky Way galaxy, Sol solar system, Earth (not Giaha), USA, WA, N.E.
Re: parallel connection
07/13/2008 12:20 PM
This seems like a rather basic question for an electrical engineer to be asking. Perhaps it is also because it is rather ambiguous. What do you mean by conditions?
They that do not learn from history and apply those lessons to the present are bound to repeat its failures.
Good Answers: 97
07/13/2008 3:35 PM
One of the two sources must be the interface controller.
The second is that both should be capable of listening.
Have a look at the GPIB interface (General Purpose Interface Bus) or its predecessor HPIB.
07/13/2008 4:29 PM
Thanks Hendrik,
I learned a little today. In my uneducated state I thought Electrical Engineering was separate from Electronics Engineering. I thought the question refered to parallel conections on batery systems.
Good Answers: 97
07/14/2008 3:32 AM
Hi Shadetree
Reading the question again in daylight made me rethink my assumption.
It do relate to electric and not electronic.
Only last week I was playing with an old plotter with a HPIB parallel interface and my mind clicked onto this idea. (The condition of the caps (1985) were also bad).
07/13/2008 5:11 PM
EE; hopefully they are close to the same voltage, perry
07/13/2008 11:18 PM
hi,
the most necessary condition for the paralled conditions are
1) same phase sequence
2) same frequency
3) same voltage rating
4) same voltage vector if both of the sources are fed from transformer
even though they must be protected through bus coupler protection or bus differentioal protectio shceme
regards
divyes patel
07/14/2008 2:28 AM
thank you Divyesh patel
your answer is the best.
what is your work field?
best regards
07/14/2008 4:11 AM
hi
currently i am working with Bombardier Transportation India limited since this may 2008,
3 years with ERDA switchgear lab,
1.5 years with Torrent Biotech Ltd
0.5 year with Exide battery
1 year with IPCL baroda.
regards
divyesh patel
08/17/2008 5:31 PM
Divyesh, how about amp rating? It seems to my memory that parallell conductors must also be of the same amp rating (size matters), and have a slot cut in the panel between conduits if separated.
I do not 'know it all', but i will admit that I would like to. CJM
Register to Reply 9 comments
CJMcGill (1); Divyesh patel (2); electrical engineer (1); Hendrik (2); perry (1); Shadetree (2)
You might be interested in: Digital Parallel and Serial Converters
