Previous in Forum: is this problem with the AVR?   Next in Forum: VCB
ohm to 4-20mA converter circuit
07/14/2008 12:35 AM
i want to design circuit that can convert ldr signal (ohm) to 4-20mA with span and zero application
Good Answers: 18
Re: ohm to 4-20mA converter circuit
07/14/2008 8:43 AM
Use a transconductance amplifier/attenuator.
You don't say what the ohm range is, so little can be said about it specifically.
What is an LDR anyway? I assume that the "R" stands for resistance.
07/14/2008 11:39 AM
LDR - light-dependent resistor?
Good Answers: 18
07/14/2008 2:21 PM
Oh! A photocell! Of course!
In that case, since the LDR needs a supply and a sense resistor connected in a divider circuit, if the "dark" resistance is too high to squeeze 4 mA through it practically, then a few electronic components may be needed to properly condition the signal.
Ideally, the "darkest" resistance and the "lightest" resistance would be such that a divider resistor could be used which would cover the 4 - 20 mA range just perfectly. The odds of that happening are slim, at best.
Nevertheless, if LDR is indeed a "light dependent resistor" or photocell, and a few operating parameters can be given, then it's just a matter of scratching out a simple circuit to get what's needed.
PW, please note that I'm replying to you as well as the original poster, whom I haven't heard from yet.
Bill
07/15/2008 3:47 AM
Have a look at XTR101 (or others of this series) from Texas Instruments, it`s a reliable circuit for your application requiring only some passive Rs and Cs for a complete design.
You can have voltage-, current- and resistive input for a broad range of sensors.
Regards Uwe
The sum of intelligence on earth is a constant. And the population grows and grows and .....
07/15/2008 7:49 PM
Use this circuit as a starter. If your LDR is different than one in this circuit, change R1 (possibly upwards), R31 and R41.
Note that the span adj. has effect on zero adj. VDD=5V, VCC=12 to 24V.
Bill (2); feridun (1); PWSlack (1); uweka (1)
