Previous in Forum: Countering torque reaction with a properly designed stator in a jet drive.   Next in Forum: how to produce magnesium chloride from sea water?
calcuation of sag and cable span
07/14/2008 1:08 PM
how to calcualte the sag and span of a aerial telcom cable.
How to calculate the wind force in hanging cable (aerial cable in saudi arabia).
Re: calcuation of sag and cable span
07/15/2008 5:11 AM
catenary
"It is only when we die that we become Immortal."
07/15/2008 10:58 AM
Which is a hyperbolic function.
Travis
07/15/2008 11:25 AM
Is this a trick question?
Hobbies - HAM Radio - New Member Engineering Fields - Mechanical Engineering - New Member United States - Member - New Member
Good Answers: 22
07/15/2008 9:07 PM
Shouldn't Del be answering this one?
I wonder..... Would Schrödinger's cat play with a ball of string theory?
07/15/2008 6:35 AM
<...how to calcualte the sag and span of a aerial telcom cable....>
The catenary equation is that of the hyperbolic cosine mathematical function. The rest is arithmetic.
Good Answers: 27
07/15/2008 9:42 AM
For level span sags, an approximate parabola equation can be used for span lengths below 300 meters (1,000 ft) or where sag is less than 5% of the span length.
S = WcL²/8Th
where:
S = sag at center of span in meters (ft), Wc = conductor weight in Newtons per meter (lbs per foot), [for standard gravity 1 kg = 9.81N), L = span length in meters (ft), and Th = horizontal tension in Newtons (lbs).
The exact formula for determining level span sag is:
S = Th/Wc (cosh WcL/2Th - 1)
The wind force on cylindrical surfaces can be calculated:
Pressure in lbs/ft² = 0.00256 (v)² where v = wind velocity in miles per hour or:
Pressure in pascals = 0.613 (v)² where v = wind velocity in meters per second.
That force is applied to the exposed area (diameter) of the cable.
Register to Reply 6 comments
3Doug (1); Anonymous Poster (1); Bluestone (1); High Lander (2); PWSlack (1)
