Previous in Forum: III Year Student Final Project   Next in Forum: L-cysine
9 comments
pic18f458
07/15/2008 5:03 AM
hi,
i need some help for progamming pic 18f 458 (adc,clr ,quartz),
thanks
Good Answers: 230
Re: pic18f458
07/15/2008 5:23 AM
Hello Guest,
I see you have the same Topic started also here: http://cr4.globalspec.com/thread/24063/pic18f458after you registered at Forum under your Member name of Kaci.
I shall ask Admin to remove (This Above One) earlier Topic Thread, to avoid confusion, and retain the Topic you started as "Kaci".
Kind Regards....
Re: pic18f458
07/15/2008 12:00 PM
thanks,
but have you ansers for my questions.
Re: pic18f458
07/17/2008 11:57 AM
What questions? None has been asked!
Re: pic18f458
07/20/2008 12:09 PM
yes,i work with the compilateur ccs
1.i want the pic18f458 opperates at 40 MHz.what i have to do.
2.i have 3 analog input (3phase)(3 sinusoide)(ampli 2.5v),
the adc conversion will be 10bit (5volt;correspond;1024) or
8bit(5volt;correspond;256)
what's the manner to program this
Good Answers: 230
Re: pic18f458
07/20/2008 6:00 PM
Hello again kaci
Do you have a copy of the Manufacturer's Instruction Book?
If so, Read through it, and follow the Maker's Instructions in that Book.
If you do not have the Maker's Instruction Book, then contact the Makers, and ask them for an Instruction Book for the Equipment you are trying to program.
If you are in a factory situation, then ask your Manager for the Maker's Instruction Book, because an Instruction Book is always supplied with Equipment of this nature.
If you do have the Maker's Instruction Book, please remember that to program such a piece of equipment does require knowledge, and your skill level may not be sufficient.
Remember that Readers do not have access to the Maker's Instruction Book, and it would be unwise to give you instructions which may not be correct for the Make, Model, Serial Number of the equipment you wish to program.
Advise your progress, with
Kind Regards....
Re: pic18f458
07/21/2008 5:56 AM
hello Sparkstation,
can you explain me more for the Maker's Instructions .
i search for manner to program;
8bit(5volt;correspond;256) )
Good Answers: 230
Re: pic18f458
07/21/2008 5:59 AM
Hello again kaci
Do you have the Equipment Maker's Instruction Book?
Advise:
  1. Yes
  2. No
Kind Regards....
Re: pic18f458
07/21/2008 10:48 AM
no
Good Answers: 230
Re: pic18f458
07/21/2008 7:16 PM
Hello kaci
I don't have the equipment Maker's Instruction Manual either.
Thus each of us would be working from a non-available Maker's Instruction Book, and that would be very foolish.
Get yourself a copy of the Equipment Maker's Instruction Book.
Refer to my earlier reply:http://cr4.globalspec.com/comment/255449/Re-pic18f458
<"....If you do not have the Maker's Instruction Book, then contact the Makers, and ask them for an Instruction Book for the Equipment you are trying to program.
Remember that Readers do not have access to the Maker's Instruction Book, and it would be unwise to give you instructions which may not be correct for the Make, Model, Serial Number of the equipment you wish to program.....">
Kind Regards....
kaci (4); PWSlack (1); Sparkstation (4)
