Previous in Forum: Can a centrifugal pump be considered a low-shear pump?   Next in Forum: drain in inst. air system
18 comments
Mechanical Work
07/16/2008 10:10 PM
While I was reading the paper "penguin waddling is not wasteful",
I found some paragraph which I could not understand.
Ask you guys explain it for me, thanks in advance.
Many animals reduce the muscular work of walking by exchanging the gravitational potential energy and kinetic energy of the center of mass, like an inverted pendulum. But penguins' waddling gait appears to involve large fluctuations in lateral kinetic energy and a poor exchange of mechanical energy.
what does this paragraph mean ?
How the muscular work can be reduced if gravitational energy and kinetic energy are exchanged ?
I think I am misunderstanding the key concept of work... pls help !!
8
Good Answers: 230
Re: Mechanical Work
07/16/2008 11:17 PM
Hello nzur
There are two separate sentences, which you have (in your mind) joined together as a single sentence, mentally omitting the joiner word:- 'but':
<"....Many animals reduce the muscular work of walking by exchanging the gravitational potential energy and kinetic energy of the center of mass, like an inverted pendulum.....">
This is regarded as the 'normal' mode for animal 'walking', the finest example of extremely reduced muscular energy for forward motion, would be the kangaroo.
The kangaroo, also wallaby (associated species), stores energy in the large elastic leg tendons, much like a boy on a Pogo Stick, where the spring absorbs energy upon landing, then releases all that stored energy, less heat and friction, on the rebound (upwards stroke as the boy jumps again on the 'bounce').
The design of the kangaroo, thus allows it to live efficiently in a semi-desert, without overheating during motion, where other methods of animalicular motion would surely see the user die, because of larger requirements of food and water.
Likewise the camel, designed to walk both left feet, then both right feet, unlike almost all other quadrupeds, because the camel design is also for food/water efficiency, in the similar climate.
The sentences are 'joined' by the word 'but' which shows ideas in the second sentence are contrasted against the earlier sentence.
<"....But penguins' waddling gait appears to involve large fluctuations in lateral kinetic energy and a poor exchange of mechanical energy.....">
The penguin is not designed for speed on land, although they are very efficient swimmers.
The 'large fluctuations in lateral kinetic energy' is a scientific way of saying the penguin 'waddles', in a 'side-to-side' (laterally) manner similar to the way a duck walks - see the animated picture at left.
'Poor exchange of mechanical energy', means that unlike the kangaroo, camel or boy on the Pogo stick, very little energy is saved in elastic tendons for re-use.
This means that the penguin thus requires more food (fuel) in proportion to its body mass.
Oil-rich fish, which is the penguin's normal food, is a very concentrated form of food energy, and because the loss of energy is larger in the penguin than in other similar-sized birds, (the locomotion is not very efficient), when that food (fuel) is burned up in the muscles, because of the cold climate, the penguin does not normally overheat, and it moves slowly, which also releases that heat slowly.
Thus you should not normally see penguins in the tropics, or 'walking' (waddling) very fast, because they would overheat and die very rapidly.
Hope that assists you.
Kind Regards....
Register to Reply Good Answer (Score 8)
Re: Mechanical Work
07/16/2008 11:25 PM
Great answer !! Thank you very much ^^;;
Best regard.
Good Answers: 230
Re: Mechanical Work
07/16/2008 11:28 PM
Hello nzur
Thank you for the fastest "GA Point" I have ever received.
Kind Regards....
Re: Mechanical Work
07/18/2008 12:19 PM
Sparky; Thank YOU for the best "answer to a biology question by a non-biologist" I have ever seen! That got you the 8th GA vote from me (and nzur's polite thank you got a 2nd one from me too, because politeness should count for something). In fact, the only point, and it is a minor one, that I can add, is that being fast swimmers, any excess heat generated by said penguin whilst flying through the water (which is essentially what they do) is dissipated by the more efficient heat transfer medium - cold water.
Location: Globaly - very close to the southern most point of Canada
Good Answers: 12
Re: Mechanical Work
07/18/2008 8:08 AM
Sparkstation...... great answer.
I found your engineering terminology "The design of the kangaroo" interesting.
-why bother doing it wrong when it will be anyway.......
Good Answers: 11
Re: Mechanical Work
07/18/2008 3:07 PM
I would give you a GA but i think you still need some challenges in life so I will let you tick along on 8.
Just 2 minor points. Some horses and ponies actually use a lateral gait, icelandics do it and a number of others. It appears to be genetically linked as some animals find it easier than others and it can be bred for, (though they may just learn from watching mum) but apparently the military desired a trot, ie working diagonals so bred away from the lateral pace. But i am fascinated that the lateral pace is more fuel efficient and would like to know where to find more info on the subject.
The second point I want to mention is that there is a study underway looking at the gait of the elderly and comparing it with penguins. Apparently there are some major benefits in balance in (I think) training the elderly to walk like penguins.
Neither of these points detract from a really good answer.
Simon
horsepower measures work, ponypower measures pleasure!
Re: Mechanical Work
07/18/2008 5:10 PM
To walk like a penguin is encouraged in our organization ... the idea is to make small steps thus controlling the balance, especially on snow covered parking lots... J.
All of us could take a lesson from the weather. It pays no attention to criticism.
Good Answers: 143
Re: Mechanical Work
07/17/2008 6:40 AM
I don't know of a good free link to give you, but you might try searching on gait energetics and adding inverted pendulum if needed as a filter. There's no quick and simple answer. But, I can tell you to not use only the concept of mechanical work (Fd) when dealing with physiology.
Re: Mechanical Work
07/18/2008 7:17 AM
If you observe a penguin waddling, you will note that he picks up his foot, advances it forward and then seemingly "falls" forward to move along. That is taking advantage of the gravitational forces. Then, as his step continues, he is actually appearing to fall forwaord with each advancing step. That is the kinetic energy being utilized. As he "falls" forward, he is not actually using his energy to move ahead, it is the combination of the kinetic energy and the gravitational energy that propels him. Very novel idea. He walks and advances, but with very little of his own energy expended. The biggest expenditure of energy comes in the act of lifting his foot off the ground.
Good Answers: 143
Re: Mechanical Work
07/18/2008 8:36 PM
nzur
Here's a link that shows different gaits and some of the math.
http://s.i-techonline.com/Book/Humanoid-Robots-Human-like-Machines/ISBN978-3-902613-07-3mrmi11.pdf
Re: Mechanical Work
07/19/2008 4:42 AM
It's very nice of you to show this link...
Thank you very much TVP45 !!
Re: Mechanical Work
07/21/2008 9:01 AM
And to think, it all started when someone asked Muybridge about a racehorse...
Good Answers: 143
Re: Mechanical Work
07/21/2008 9:24 AM
I have slow motion films, showing that racing penguins often have both feet off the ground.
Re: Mechanical Work
07/21/2008 9:44 AM
Good Lord, man - do you realize what this means?!?
Good Answers: 230
Re: Mechanical Work
07/23/2008 12:45 AM
Hello EnviroMan
Your penguin has stopped moving, and is frozen in time.
Kind Regards....
Re: Mechanical Work
07/23/2008 9:32 AM
Frozen in time beats frozen in ice, I reckon...but now he'll never win the penguin races, dangit!
Re: Mechanical Work
02/06/2009 7:45 AM
"...How the muscular work can be reduced if gravitational energy and kinetic energy are exchanged ?..."
Bipedal walking is an excellent example:
In bipedal walking, say, a man, you in fact tip yourself off-balance forward with one leg, and catch yourself back into a momentary balance with the other foot. This is one step of course, while in actual, continuous, walking, this one-cycle is repetitive.
in tipping yourself off balance yo convert your existing forward motion (kinetic energy) into some sort of "falling", which is now transferred to gravitational energy taking place.
Now, you don't allow yourself to fall all the way to the ground (oops!) but instead, you send the other leg (opposite to the tipping leg) forward to sort of "Catch" the falling body, and while using it as a stilt, you tip your center of gravity over it, thus transferring your potential energy back from gravitational "fall" into (kinetic) forward motion again.
This re-cyclic motion, reduces the chemical energy produced by you muscles to maintain your movement, by replacing some of kinetic energy produced by your muscles burning calories, with the constant 1G available for "Free-Falling" as well as some load-barring of using your leg bones as a stilt - to bridge over that tipping - in order to move forward ready for the next "Fall".
This load creates pressure, which in turn, dissipates as heat.
Re: Bipedalism implemented in robotics
02/07/2009 7:00 PM
Register to Reply 18 comments
crownvic (1); EnviroMan (4); gdevine (1); Jaan (1); nzur (2); saddlechariot (1); Sparkstation (3); TVP45 (3); Yuval (2)
