Previous in Forum: 7th grade Physics Student   Next in Forum: What is best way to learn Chinese
10 comments
Gyro
07/17/2008 1:32 PM
Is there such thing as a gyro that adjusts position itself rather than sending the data to external motors to adjust position? If so where might I find it? Any help would be appreciated as I do not have a deep understanding of gyros.
Pathfinder Tags: gyro
Re: Gyro
07/17/2008 1:56 PM
Re: Gyro
07/17/2008 2:26 PM
I am looking for something on a larger scale, needing to adjust/control 50-100 lbs.
Re: Gyro
07/18/2008 12:43 AM
Try the aircraft wreckers for the Inertial navigation system components. The Very Early ones worked directly, however they had a 1/2% error rate which isn't any good over distance, being 1 mile off course in 200 mile distance!
There are model Helicopter Gyros and Ring lazer gyro simulators which might be adapted to drive a heavy servo or two.
Finally the old Gunnery sight stabilisation Gyros used on warships were direct drive, but I think most of them have gone to god by now!
Re: Gyro
07/18/2008 6:37 AM
how much bedget do you hve?
Re: Gyro
07/17/2008 2:37 PM
The little ones we used in the Milan anti-tank missile were pretty impressive...
However, they had a very limited lifetime!!
Good Answers: 109
Re: Gyro
07/18/2008 3:23 AM
Hi,
A: try to get a copy of Savet: The Gyroscope, Theory and Applications, Wiley 1964 or so. A lot of useful infos.
B: A gyro maintains its angular orientation with respect to an inertial frame. So if you want to stabilise something you have to get a gimballed suspension (2 axis minimum, up to 5 axis nested one inside the next if moved on a vehicle.)
The bearings of the gimbals have to be of utmost quality, balancing too, temperature stabilising ...
C.: You can get short time medium quality stabilisation with a passive gyro. Post your requirements!
RHABE
Re: Gyro
07/18/2008 5:35 AM
it principle of angle momentum conservation. high speed rotation object keeps its axes direction unchange.
I remember, ship use it for it stabilize.
Popular Science - Weaponology - Scapolie, new member.
Re: Gyro
07/18/2008 5:56 AM
Hi Gmm,
Google; Gyroscope. com They have an electronic gyroscope at a cheap price!
Spencer.
Re: Gyro
07/18/2008 6:40 AM
Commercially, the artificial horizon used in aircraft instrument panels contains a gyroscope that maintains a horizontal orientation. As others have said, you can buy toy gyroscopes and they are fun to play with.
Re: Gyro
07/18/2008 9:47 AM
Thanks for all the info, and I'll try to get some requirements posted soon.
Register to Reply 10 comments
Anonymous Poster (2); bhankiii (1); cnpower (2); Electroman (1); Gmn (2); RHABE (1); Scapolie (1)
You might be interested in: Inertial and Gyro Systems, DC Motors, Stepper Motors
