Previous in Forum: Type of SCR firing   Next in Forum: Free software in Electrical design
Crane Invertor
09/17/2006 3:18 AM
What about using invertor on the big cranes (350 tons)?
You have some advise regarding these matter?
Thank you very much.
Re: Crane Invertor
09/18/2006 12:56 AM
hi mionita
It is possible and very common pratice to use invertor drive to control all tonnage of cranes for hoisting and lowering application. The invertor drive you need to used must came with a tension mode or more commonly call (Torque control).
Best Regards.
cher
Re: Crane Invertor
09/18/2006 5:10 AM
yes. you can use invertor for any crane. we can offer you such invertor. tell your required voltage and phase and hz.
Re: Crane Invertor
09/18/2006 8:53 AM
Compare the crane motor's torque-speed requirements for the crane application to the inverter curves like the speed-hp curve. Inverters are often (or maybe always) constant hp meaning that when motor speed goes above 60 hz (above normal full speed) the torque reduces. This occurs because hp remains constant.
Register to Reply 3 comments
cnpower (1); khcher (1); MikeHengineer (1)
