Previous in Forum: procedure   Next in Forum: Theories on water
plate type heat exchanger
07/28/2008 6:51 AM
why we are using stainless steel plates for plate type heat exchanger. even thermal conductivity of ss is lowest 17.5 w/m degree cel. at 125degree cel. please see the picture.
thoughts becomes things.
Re: plate type heat exchanger
07/28/2008 7:37 AM
What are the process and utility fluids, their temperatures and pressures?
What other materials are under consideration for these plates?
07/28/2008 9:53 AM
let say for example condensate water (100degree cel.)against normal water
pressure 5 bar
my doubt is why we are using ss material
07/28/2008 10:46 AM
Hot condensate is very aggressive. Were mild steel to be used for plates, the chances are that at those sort of thicknesses, it wouldn't last very long.
That type of heat exchanger starts at stainless steel, and the material quality goes upwards from there. Mild steel plates of that type are probably not available.
The exchanger type originates with, among others, the APV company, whose origins lie in milk processing. Mild steel and milk do not mix, for obvious reasons!
Register to Reply 3 comments
