Previous in Forum: starting a pump   Next in Forum: plate type heat exchanger
procedure
07/28/2008 2:31 AM
wat is the basic procedure of metal coloring thru boiling chemicals
Re: procedure
07/28/2008 3:23 AM
Which metal?
Re: procedure
07/28/2008 5:13 AM
medium carbon steel
Re: procedure
07/28/2008 6:35 AM
Carr's "Metal Black" (usual disclaimer) works pretty well. It can be had from all good model shops. It is applied at room temperature with a small paintbrush.
Re: procedure
07/28/2008 10:50 AM
Anodised aluminium is clear and needs to be 'fixed' soon after anodising by being put into boiling water.
Any dye can be added to the water to give the colour you want.
That's the only procedure I know of that uses boiling chemicals.
Register to Reply 4 comments
Anonymous Poster (1); Electroman (1); PWSlack (2)
