Hi! I've got a large air regulator (2") that is air pilot operated. It has a pilot ratio of about 1:1, where, to obtain an output of say, 100 psi, one needs to supply a pilot pressure of 100 psi. (Its actually a bit more than this, because of internal friction of O-rings and a small spring, the valve takes about 106 psi to output 100 psi.) Naturally, the input pressure needs to be above 100 psi.
I want to modify the valve to make it operate with a pilot ratio of about 2:1, so 50 psi on the pilot diaphragm would output 100 psi. This required because I do not want to set up a new pilot pressure system that supplies air pressure higher than the plant air pressure just to operate these valves. There are 3 valves per plant, and two plants, for a total of 6 of these valves, so a simple fix is desireable.
The manufacturer of this pilot operated pressure regulator has been no help.
To do this, I need to isolate the diaphragm in the regulator so the downstream, regulated, air does not press on the underside of the diaphragm to balance the pilot pressure. This isolation is not difficult--a bit of machining and the insertion of a blanking plate will do the job.
However, once I isolate the diaphragm, I need to provide a "divided" downstream pressure signal back to the underside of the diaphragm to provide the pressure feedback to the valve. This is where I am asking if there is some sort of "divide by n" pilot valve available. I think it might be something out of the old "Pneumatic logic" days but I'm hoping there might be someone still around who makes air logic parts.
Can anyone help--in either suggesting suppliers who might have the little valve I'm looking for or to use other clever tricks to achieve the result I'm looking for? I cannot afford to replace all six 2" valves!
Thanks,
Jon.
