Previous in Forum: Sheet Metal Process   Next in Forum: BEARING RECLAIMATION
spray system
07/29/2008 10:22 AM
To whom it may concern,
My name is Thomas Thiel, I am looking for a company that can quote me a system that will spray a coating on the inside of a steel backed babbit based bearing (samples can be provided), I have a quote from one company which has the necessary items needed. we currently outsource this procedure but want to bring it internal. I am either looking for a turn key system to buy or a quote on the items listed below. The system needs to have:
1- spray booth (table top)
1- diaphragm pump with 2 into 1 regulator, dual regulators, dual regulators, 5 gallon suction rods, and circulation kit.
1- explosion proof single pass paint heater.
1- 5 gallon SS agitator lid with air manifold assembly with quick disconnect.
2- automatic spray guns (Kremlin A-25 or similar)
2- Automatic circulating gun bases
2- Round spray nozzle and extension 3/4" with 360 degree spray.
1- desiccant air dryer with coalescing oil filter
2- ARO runaway valves model 63504 (or similar)
We would like the two spray guns to be activated by a push button. The guns could be mounted either above or below the part but needs to be adjustable. If you have any questions please don't hesitate to call.
Thank you,
Thomas Thiel
Thomas
Re: spray system
07/30/2008 8:53 AM
Are you depositing the babbitt using the spray process or some type of paint?
"I had not anticipated that the work would present any great difficulites" SHACKLETON
Re: spray system
07/30/2008 9:10 AM
no, we are going to spray a teflon like product on the inside of the bearing. So it is just a high performance coating
Thomas
Re: spray system
07/30/2008 9:01 AM
Check out Globalspec.com, they have a good listing of spray coating equipment suppliers that will be able to quote on what you need.
Re: spray system
07/30/2008 9:11 AM
Thanks I will do that!
Thomas
Register to Reply 4 comments
gump24 (2); HullRider (1); NiCrMoNoMore (1)
