I have a simple question regarding a bus bar configuration. First, a description:
Race track configuration of bus bar (approx 100m x 6m).
5 approx equal length sections fed from different MCC buckets. Sections are isolated (though arrangement of L1,L2,L3 are maintained).
several travel units use the track - though never more than 4 in any given section.
travel units have dual collectors, so one of them will always be in contact with a power section.
Question: In the 2-3 seconds of time when the travel unit transitions from one section to another - the collectors will connect the 2 sections. Is this typical? will there be any detrimental effects? If so, what? If not, why? My "purely theoretical" concern is slight variations in voltage drop at any given moment in time causing undesireable currents to force the voltages to be equal (i.e. sparking...).
The several feeds are from a common MCC - so feeders are approx equal lengths, cable/bus sizing has been set to keep max voltage drops to ~2%.
Any comments are appreciated.
thanks in advance
This is being designed by a bus bar manufacturer, but when I asked them - the only answer I recieved was effectively "don't worry about it"... and before anyone comments regarding finding a different supplier who's a little more cooperative - they were not my choice - but I'm required (on this project) to work with them.
