Previous in Forum: static pressure & density relationship   Next in Forum: Determining the size of a motor to drive the gate
Back pressure control valve
08/04/2008 7:01 AM
What is the difference between Back pressure control valve and pressure control valve and what is Choke valve?
Re: Back pressure control valve
08/04/2008 8:07 AM
In what context? What is the working fluid, temperature and pressure?
08/04/2008 8:42 AM
The working fluid was sour gas at pressure 1500 psig and temp. 150 F although I think the usage of such valves(valve type) doesn't depend on the pressure and temp. but affect the valve size, trim material, etc
08/04/2008 9:59 AM
there is no difference between all three. Back pressure valve means the valves postion is set in order to automatically maintain a constant pressure on its inlet side. A pressure control valve recieces a signal to automatically hold a constant pressure on eith its inlet, outlet or some other pressure in the system. A choke valve is a control valve that typically has a manual set postion that allows a reduced flow through the system, it can also be set to automatically controll the flow through a syste,
Register to Reply 3 comments
omar1 (1); PWSlack (1); vicini (1)
