Previous in Forum: Utility Mark outs   Next in Forum: diameter of deformed reinforcing steel bars
Underground Water Tank Specification?
08/06/2008 4:25 PM
Please comment on slab and wall thickness, rebar size and number?
Need minimum requirements.
Cheers
Underground cement water tank
Length Width Hight Cubic meter
3.4 3 2 20.4
Labor
Concrete cost Total
11.132 45 500.94
350 kg /cubic meter resistant
Steel
Steel de. Bar/ton kg/m
Ø 10 135 0.617284
Ø 12 94 0.886525
Ø 14 69 1.207729
Ø 16 53 1.572327
Description Ø Bar/ton Place Qty Length Width T. meter T. kg
Top slab top Ø 14 69 bed 7 3.4 3 71.4 86
Ø 12 94 cover 6 3.4 3 61.2 54
Top slab bottom Ø 14 69 bed 7 3.4 3 71.4 86
long wall top Ø 12 94 bed 5 3.4 2 34 30
Ø 10 135 cover 5 3.4 2 34 21
long wall bottom Ø 12 94 bed 5 3.4 2 34 30
Short wall top Ø 12 94 bed 5 3 2 30 27
Ø 10 135 cover 5 3 2 30 19
Short wall bottom Ø 12 94 bed 5 3 2 30 27
Bottom slab top Ø 14 69 bed 7 3.4 3 71.4 86
Bottom slab bottom Ø 14 69 bed 7 3.4 3 71.4 86
Sum 754
Sum +5% Wast 792
cost per kg 1.47
Total 1,161
Concrete Qty Length width Hight Sum
Top slab 1 3.4 3 0.2 2.04
Bottom slab 1 3.4 3 0.2 2.04
long wall 2 3.4 2 0.2 2.72
Short wall 2 3 2 0.2 2.4
Clean concrete 1 4.6 4.2 0.1 1.932
sum 11.132
Sum + 15% wast 12.8018
cost 60
Total 768.108
Summary
Description Cost Per
Labor 501 0.206118
Steel 1,161 0.477834
Concrete 768 0.316048
Total US$ 2,430
Read a book (which is mistake free since centuries) with open heart, is the ‘map’ to happiness on earth and after life. (Houzaifa Abrash)
Good Answers: 230
Re: Underground Water Tank Specification?
08/06/2008 10:27 PM
Hello Houzaifa
Are you yourself making up this Table?
What type of ground will the tank be buried in?
How deep will the tank be buried?
Reply with
Kind Regards....
08/08/2008 4:03 PM
Are you yourself making up this Table? Yes but unfortunately it badly displayed
What type of ground will the tank be buried in? Heavy glay
How deep will the tank be buried? 2.55 meter for the botton of clean concrete.
Cheers,
Engineering Fields - Civil Engineering - New Member Philippines - Member - New Member
08/07/2008 6:26 AM
what i've seen here is a quantity calculation and cost analysis. if you are reffering to structural design of a concrete water tank design, design criteria is needed for the design analysis.
comments on your work:
  • there is no available 14mmØ (Ø14) deformed bars in the market except if you will order special sizes from the manufacturer.
  • don't forget to include waterproofing additives to your concrete.
  • if necessary, use sulphate resisting concrete for underground structures.
  • include cost for waterbars (construction joint) between the bottom slab and wall or on any construction joint at the wall. but if you can complete the base and the wall by continous pouring of concrete - forget the waterbar.
  • check the soil characteristic if damp proofing (polythene sheet & fiber reinforced bituminous paint) is required on external surfaces of concrete beneath the ground.
  • take a consideration of using cementitious crystalline waterproofing on internal concrete surface (Base & walls)
The person who knows "how" will always have a job. The person who knows "why" will always be his boss.
08/07/2008 1:24 PM
Contact the local builder of septic tanks many people use them for water storage here.
Register to Reply 4 comments
dadw5boys (1); Houzaifa (1); inhenyero (1); Sparkstation (1)
You might be interested in: Industrial Magnets, Reactors, Powder Coating Equipment
