have a 1990 cat 70 kva that was geared for 220v 3 phase
because of new fans on the new equipment we installed having a 480 voltage, we wish to change the regulator to run it at 480 volts.because at 220 , it stalls out and wires overheat
technician seems to have problem getting up to over 400 or it is slow going.
suppose we get it up to 460 or 450. will there be an ongoing problem and what do you suggest? what is least here we can run at re; voltage?
does the voltage regulator need to be a special on in this case, i.e. Tech changed it today but still we are not seeing the volts up over 400.
any suggestions, please
tks
peter
