Previous in Forum: Question on converting 220V 50Hz to 110V 60Hz   Next in Forum: What is the Different between Potential T/F and Voltage T/F
water pump
08/07/2008 2:23 AM
whether a water pump is synchronous or induction type?
Re: water pump
08/07/2008 3:14 AM
What does the plate on the motor say?
Re: water pump
08/07/2008 7:52 AM
there is no detail describing whether it is synchronous or induction type.
the details in motor are freq , amps, volts, hp, phase.
Re: water pump
08/07/2008 10:27 AM
A synchronous motor requires a field connection. Do you see some kind of field control? The rated speed on the nameplate may also be an indicator; for example a synchronous motor might have a rated speed of 3600, 1800, 1200 rpm, as compared to an induction motor were the same speeds will be a little smaller, say 3450, 1740, 1120 rpm.
When the motor runs, does the speed ever vary with changing load? Yes? - Then induction.
Unless your motor is very large, it is likely an induction motor.
Register to Reply 3 comments
drajesh1985 (1); Lendog (1); PWSlack (1)
