Previous in Forum: calaculation of vk   Next in Forum: 3 phase motor power consuption formula
Battery culculation
08/08/2008 12:38 AM
pls,need some one to help me do this calculation ,
1500watt load to with stand for 4 hour with out any interuption .
the question are :
1) what is battery amp hours
2) which is the battery to be use ? 6v,9v or 12v ? how many needed ?
This discussion was "closed" on 08/08/2008 8:21 AM. No new comments are allowed.
Message from admins:
Homework
Good Answers: 230
Re: Battery culculation
08/08/2008 1:42 AM
Hello kelevin
There are further things you need to advise, before a proper answer may be given you.
1. Resistance of load
2. Type of battery:
a) Lead acid
b) Alkaline cell
c) Li-Ion
d) Polycarbonate
e) Ni-MH
f) Other - Specify please
3. The minimum percentage of the normal battery voltage, that your load will still operate correctly with.
Once the specific details are supplied, then you may well receive a proper answer.
I do trust this is not a Class or Homework Question, because those are against the Rules.
Reply here, with
Homework
You might be interested in: Math Calculation Software, Battery Holders
