Previous in Forum: Battery culculation   Next in Forum: 33kv sub station
3 phase motor power consuption formula
08/08/2008 6:32 AM
what is the formula to calculate load of three phase motor if I have reading of amp. per phase.
Re: 3 phase motor power consuption formula
08/08/2008 8:33 AM
The electrical load is the product of the current, the voltage and the power factor.
The mechanical load is the product of the torque and the angular velocity.
The ratio of these two is the efficiency.
08/11/2008 11:45 PM
Good answer.
Can you clarify the following please :
LV Motor, rated at 7.5 KW, 415 V, 3 ph, 50 Hz.
Shaft KW = 7.5 KW ?
Load factor given as : 75 % ( 0.75 )
Given pf = 0.73 Eff. =0.85
What is the Continuous rated load ?
How to calculate the Absorbed power of this Continuous rated load ?
I think : Motor Shaft kw = Motor rated kw.
Absorbed Power ( kw ) = Rated load x Load factor/ efficiency
Equals 7.5 x 0.75 / 0.85 = 6.61 kw rated continuous load.
Is this the correct Load Study procedure using the IEC ?
or what should the following be :
Continuous rated load KW =
LOAD FACTOR = Absorbed power / Rated load ? ( I think not )
Thank you
Good Answers: 42
08/08/2008 9:14 AM
Hi Guest,
In addition to per phase amp , you must also know the operating voltage of the motor and weather the motor is star/ delta connected and power factor to calculate the electrical power consumed by the motor . It is not necessary that all the power consumed is transferred to useful load (by load if you meant by that). For calculating the useful power you must know the inefficiency of the mechanical systems.
08/10/2008 1:56 PM
Lets see : Assume you know the Horsepower Example 5 HP
1HP =746W
5HP=3745W
Assuming Y connection 208v
W=3(IxI R)
3745 dived by 3= (42x42)R
1248/ 1764=Resistance , and W=SqRoot of3xExIx cosO w already known, E known, I known . plugging in numbers
1.732 x 208 x 42 x cosO= 3745
have fun
09/18/2008 4:26 PM
I X E X 1.73 = VA (Apparent Power)
kVA X Power Factor = W (Real Power)
W / 746 = Hp
Be aware. P.F. will change depending upon the load. Nameplate P.F. is a full load value. And both the Watt & Horsepower values will not be real shaft output values. Various losses within the motor will not be reflected
Fangas (1); Jeff Millar (1); martin-electrical (1); PWSlack (1); V.I.Abraham (1)
