Previous in Forum: RECIPROCATING COMPRESSOR   Next in Forum: What is meant by "T, U, V, W, X & Z" in Heat treatment conditions.
plastics
08/08/2008 1:48 AM
hi,
while selecting plastics, raw material composition is key,
but is there any thumb rule or guide lines for selecting plastics. 2) how do i know what composition the vendor/ fabricator has used in the component ( i.e after manufacturing )
with regards & thanks,
Shivakumar.S
Re: plastics
08/08/2008 4:32 AM
<...what composition the vendor/ fabricator has used ...>
A telephone call to the vendor/fabricator would do the trick.
Good Answers: 96
Re: plastics
08/08/2008 10:49 PM
Hi,
For selecting the correct materials, first you need to know the environmental requirements (temperature, strength, ambient exposure to chemicals, etc), and then you can A) consult with your raw-material vendor, or converter (sheet stock, etc.), or B) search sites of major brands (DuPont, Bayer, GE, etc.) and review their data sheets. Most are available either on-line, or by a downloadable PDF.
For confirming what your component supplier has given you, you can ask for a 'certification' sheet by shipment of what was used, and (more and more this is becoming a requirement) you can ask for an IMDS (international material data sheet) which, if done correctly, will show you by percentage and weight everything contained therein. This certificate or IMDS can be very important as most component manufacturers do at least SOME blending (colors, fillers, etc.) and that can radically change the nature of the base material. If you're using a component vendor who can't or won't supply you the data you need, my strong advice is to change vendors as soon as possible. Truly, this data is becoming more and more a requirement from YOUR customers, and if you can't be assured of the data, your company may be liable for defects and non-compliance of material content.
I hope this helps some.
Kind regards ...
"Just when I had all the answers, they changed all the questions"
Re: plastics
08/09/2008 11:40 AM
You have to resort to the techniques of "Engineering Properties of Materials": the standard properties of every plastic material is known, so contrast your test values against the standard values to check for deviations from the standard values.
EditorGBAnalysts - Give a boy fish and he will eat may be for a day, but teach him how to fish and he will eat everyday.
Re: plastics
08/12/2008 12:00 AM
You can check the chemical identification of plastics from the book of Premamoy Ghosh entitled "Polymer Science and Technology of Plastics, Rubbbers, Blends and composites.
There is basis of selection of plastics for diferent applications and conditions. The basis depends on the application areas.
thanks and Regards,
Amit Chakrabarti
Register to Reply 4 comments
Amit Chakrabarti (1); DCaD (1); editorgbanalysts (1); PWSlack (1)
