Previous in Forum: Relief Valve/ Bypass Valve or Backpressure Regulator?   Next in Forum: Cheaper LED lights
Designing reflector for lights bulbs
08/11/2008 1:13 AM
Is ther a freeware for designing reflector for a light bulb?
Good Answers: 230
Re: Designing reflector for lights bulbs
08/11/2008 3:05 AM
Hello h.logtenberg
You need to specify which light bulb.
Light bulbs vary from 1.2mm diameter, to over 1.00 Metres in diameter, power from .004 Watts to over 500kW.
You would also need to advise whether that reflector was internal, external, and what you were attempting to achieve with that reflector.
Reply here, with
Kind Regards....
12/08/2008 4:37 AM
Dear Sir,
Is is for straight light bulbs with a lenght from 0.1 tot 1.60 metres en a diameter of about 20 mm.
regards,
Harry Logtenberg
Good Answers: 230
12/08/2008 7:23 PM
Hello h.logtenberg
From your description these straight tubular lamps must be fluorescent lamps.
If so, the reflector design does not really need any software or calculation.
The reason is because the gas discharge between the end electrodes of a fluorescent tube is mostly ultraviolet light inside the glass envelope.
If the glass was clear, all you would see is a dark purplish coloured discharge thin column through the gas in the tube.
To make a fluorescent lamp efficient emitters of light visible to people, toxic phosphors of various types are sprayed against the inside of the glass tube.
The ultraviolet light from the discharge column inside the tube excites the phosphors, they in turn being excited radiate the energy mostly in the light spectrum which is visible to us.
Consequently, the radiating surface of the light is spread over the circumference and length of the lamp - it is not a concentrated light source such as a small filament.
Thus almost any reflector, shiny or painted white will do as a reflecting surface.
If your lamp/s are not fluorescent types, please advise with proper description, and further advice may be given.
Kind Regards....
12/08/2008 4:33 AM
By any chance are you looking for open source CAD software ?
In such a vast universe, I can only bask in my own insignificance....
Register to Reply 4 comments
csoulpro (1); h.logtenberg (1); Sparkstation (2)
You might be interested in: Reflectors, Dial Thermometers, Antennas
