Previous in Forum: Is That True E-mail From Yahoo?   Next in Forum: volume of oval cylinder
Perspex
08/12/2008 7:28 AM
what can be used to join perspex
Re: Perspex
08/12/2008 8:06 AM
  • Nuts & bolts
  • Pop rivets
  • Cyanoacrylate adhesive
  • Ultrasonic welding
  • Solvent welding
  • UHU (usual disclaimer)
  • Impact adhesive
  • Silicone sealants
  • Epoxy adhesives
  • Etc, etc.
Re: Perspex
08/12/2008 9:04 AM
That ETC is damn fine stuff .
Good Answers: 230
Re: Perspex
08/12/2008 4:30 PM
Hello Del the cat etc,
I use, etc, that ETC in all sorts, etc, of situations, etc.
It does, etc, the job, etc. extremely, etc, well, etc.
Kind Regards, etc....
Good Answers: 230
Re: Perspex
08/12/2008 8:21 AM
Hello Guest,
It depends on what type of joint you are talking about, and I am unable to read your mind.
Bolts, screws, nails, glue, silicone sealant, there are hundreds of different things and ways to do what you ask.
Acetone, Chloroform, MEK, and other Solvents can soften and dissolve Perspex, and be used to make invisible joints, if you are careful.
Solvents which dissolve Perspex are all organically based, very toxic, require proper care in use, are inflammable and/or explosive in spark situations in air.
If you do not have the proper training and equipment to work with organic solvents, do not attempt using these.
Reply with
Kind Regards....
Re: Perspex
08/13/2008 2:14 PM
Try these guys - they sell Perspex and should be able to advise on what you need: www.theplasticshop.co.uk
Anonymous Poster (1); PWSlack (1); Sparkstation (2); user-deleted-1105 (1)
