Previous in Forum: alternative to Shellsol R and Hexylene Glycol   Next in Forum: Shatter proof plastic
12 comments
viscosity
08/14/2008 4:47 PM
how can i measure viscosity of fluied like glycerine and soap
what is newtonian and non newtonian fluied
what is glycerine and soap newtonian or non newtonian fluied
please advice me
thoughts becomes things.
Re: viscosity
08/14/2008 5:35 PM
A Newtonian fluid has a constant number for its viscosity while a non-Newtonian fluid has viscosity that changes with the velocity gradient applied to it.
Both glycerol or glycerin and soap are non-Newtonian: Very often the fluids with complex molecular structures, as are glycerin and soap, are non-Newtonian.
I think there are viscosity meters, just google it - just checked and found one on Globalspec.com
EditorGBAnalysts - Give a boy fish and he will eat may be for a day, but teach him how to fish and he will eat everyday.
Re: viscosity
08/15/2008 7:01 AM
we have glycerine of 1.285 specific gravity
can u please tell me how much will be the viscosity approximately.
Re: viscosity
08/15/2008 8:30 AM
It's not possible. It depends upon temperature, for one thing, which isn't stated here.
Re: viscosity
08/15/2008 2:02 AM
By viscometer, device for measuring viscosity; commonly in the form of a calibrated capillary tube through which a liquid is allowed to pass at a controlled temperature in a specified time period.
Also, see Wikipedia, the free encyclopedia: Today, a rheometer is a laboratory device used to measure the way in which a liquid, suspension or slurry flows in response to applied forces. It is used for those fluids which cannot be defined by a single value of viscosity and therefore require more parameters to be set and measured than is the case for a viscometer. It measures the rheology of the fluid.
There are two distinctively different types of rheometers depending on the geometry of applied stress. Rheometers that deal with shear stress are called shear rheometers, whereas rheometers that apply extensional stress are extensional rheometers.
Re: viscosity
08/15/2008 1:59 PM
Non-newtonian fluids are those that have viscosity dependent on shear rate. Shear rate measures how quickly the fluid is being poured (or deformed, it it's too thick to pour.)
Rheoplectic - visconsity increases with shear rate. Think silly putty. Leave it alone, it flows, hit it with a hammer, it shatters.
Thixotropic - viscosity decreases with shear rate. Think ketchup. Turn the bottle upside down, it stay there. Shake it, it quickly pours out.
Re: viscosity
08/15/2008 3:57 PM
what about soap
is it rheoplectic or thixotropic?
Re: viscosity
08/15/2008 8:48 PM
I'm an engineer, not a chemist, but I believe soap is thixotropic, based on the fact that soap and oil together make grease and grease is thixotropic.
Re: viscosity
08/16/2008 1:29 PM
actually i want suggestion from engineer
if soap is thixotropic which viscosity increase with shear rate
and centrifugal pump is high shear pump is it adviceable to use centrifugal pump for pumping soap
we are using both centrifugal high shear pump and lobe pump low shear pump
but the line leakage of lobe pump is too much
what will be the reason
how can i solve this problem
now i m trying expansion joint
Re: viscosity
08/16/2008 7:42 PM
I would not use a centrifugal pump for soap. The pump may be high shear, but the piping would not be. You'd probably end up with a layer of soap on the OD of the pump and an empty space inside. Use a positive displacement pump.
I'm just a little bit out of my normal field here. Anyone with additional input?
Re: viscosity
08/18/2008 2:06 PM
Can you contact the soap manufacturer? Or maybe another soap manufacturer?
Diaphram (if chemically compatible) or piston sound best to me.
Re: viscosity
08/18/2008 2:50 PM
i have lobe pump to transfer soap
but the problem we have knoking vibration in transfer pipe line how can i eliminate
Re: viscosity
08/20/2008 8:23 AM
As said, this is a little out of my normal experience but, since no one else is here, I'll do my best.
How thick is the soap? Are we looking at shampoo, or material to be cast into bars of soap?
There is a good chance you're getting cavitation. The soap is thick enough that it doesn't completely fill the space left by the lobe. The next lobe collapses that void causing a "water hammer" effect. You might try increasing the pressure at the pump inlet, maybe by lowering the pump or raising the reservoir, and/or slowing the pump to give more fill time.
Register to Reply 12 comments
Abdel Halim Galala (1); editorgbanalysts (1); HarryBurt (5); PWSlack (1); sandeep lokhande (4)
