Previous in Forum: Gas/Steel/Dual Dampered - Springs   Next in Forum: LPG Calculation Formula
ss 304 welding dc current
09/23/2006 8:24 AM
i m regular reader of cr4.
i m fab. engg. i want what should be dc current for ss 304 tig welding for 2.5 mm ss308 L filler & 4, 5 mm thick plate.
for
case 1 - for root run
case 2- final run.
also max. gap allowable betn two plate?
if gap is 10 mm betn two 5 mm thk plate, what should i do?
pl. suggest me solution.
my mail ID- kbkparesh@yahoo.co.in
REGARDS.
PARESH
Re: ss 304 welding dc current
09/25/2006 10:09 AM
You usually don't want the gap between the plates to be any bigger than your filler material thickness. It also depends upon the application. I know that food service applications require certain prep procedures applied prior to welding. You are probably looking at running anywhere from 2 to 5 passes to cap out on 5 mm plate so you will need to watch heat input carefully to keep from damaging the base metal. Not sure hot you will want to weld at, it differs from person to person depending on what they like to do.
An expert is someone who has made a large amount of mistakes, in a small field of work.
Reply to Forum Thread
