Hey everyone, I have a rather odd question. I'm trying to make a tricky kind of interior mold for metal casting and I'm wondering if there's an accessible element or compound that has these particular properties -
1. It will perform sublimation at a fairly easily attainable pressure and room temp (or close to it). Pressure will probably have to be below 1 atm but it has to be something that I can create without super fancy gear.
2. I can easily transition it from a solid state to a liquid state by adding or subtracting heat with in the range of -20 degrees C to 90 degrees C.
3. It's not toxic etc. I can work with it ok.
Any ideas?
I'm guessing sense I'm dealing with all three forms - solid,liquid,vaper the key is that the TP point be as close to atmospheric pressure as possible (while still under it) and also be as close to room temp as possible. But I'm not a chemist so you tell me
Thanks in advance for the help!!!
Bradley
