Previous in Forum: Shatter proof plastic   Next in Forum: Phase Change Madness!
What (if any) effect does temperature have on electrolysis of water?
08/15/2008 5:42 AM
When hydrogen is produced by electrolysis, is the process efficiency increased for an elevated solution temperature?
Thanks.
Good Answers: 143
Re: What (if any) effect does temperature have on electrolysis of water?
08/15/2008 7:56 AM
If you mean: do you get more gas per Amp, the answer is yes.
If you mean: do you get more gas per Joule, the answer is generally no.
08/15/2008 8:28 AM
Efficiency? No.
Rate? Yes.
08/16/2008 12:24 PM
Does that mean:
If temp higher current flows faster through cell for fixed voltage?
Meaning, does the eletrolyte's resistance change with temp?
08/18/2008 3:49 AM
Yes, on both questions.
08/16/2008 12:30 PM
Erm, I just found this:
http://en.wikipedia.org/wiki/High-temperature_electrolysis
Any comments?
Thanks
Good Answers: 143
08/18/2008 8:05 AM
Yes. Read the WIKI article very carefully. It sounds for all the world like a press release for sales of that process.
The key is that the high efficiency (they actually quote greater than 100% !!) comes as a result of being able to pick up free thermal energy from the mysteriously available surroundings. Heck, if I could magically find pennies scattered about, I could afford a "free" milling machine.
For those who think I'm an curmudgeonly OF for not liking WIKI, this is why.
This general thread, however, does point out that there is a huge reservoir of wasted heat energy out there that might be available to increase efficiencies of existing processes. That seems a promising path, but is very poorly funded at the moment.
08/19/2008 7:37 AM
Mmmm... I see what you mean - 135% efficiency. Not a promising sign I agree!
The other link to a US Dept of Env. pdf looks a bit more solid:
http://www1.eere.energy.gov/solar/pdfs/doctor.pdf
Page 4 shows a graph illustrating lower energies with high temps.
From this I conclude there is reasonable savings in overall energy needs if high temps are used.
Initially, when I first started this thread, I was wondered about was: Could waste heat from an IC engine be used in conjection with a high temp cell to generate H2?
Register to Reply 7 comments
PWSlack (2); Sheps (3); TVP45 (2)
