Previous in Forum: Load Calculation   Next in Forum: elecrical fan
8 comments
Two-Phase Machines and Four-Phase Power
08/18/2008 3:48 AM
where do we find most of the applications of 2-phase machines?
and do we practically use 4-phase or any other no of phase other then 1 and 3 phases?
please tell me abt these things...
Re: phases
08/18/2008 5:08 AM
  • 3 phase supplies all that is needed for smooth power transmission between generator and user, for the minimum amount of conductor material.
  • 3 phase tansforms easily to 3 x single phase by introducing an earth connection at the star point of the local distribution transformer.
  • Everybody's doing it.
Re: phases
08/18/2008 5:28 AM
i know tht 3phase supply is very common
i just wana knw whether other phases exixts and if yes y arent thy are in so much of use...
Re: phases
08/18/2008 7:27 AM
Re: phases
08/26/2008 10:49 AM
One of the main use of electricity, besides lighting, is to convert electrical energy to mechanical energy. That is mostly done by motors.
Even number of phases cancel each paired phases out because because they are 180 degrees apart, equal in magnitude but opposite in 'direction'. Thus they are unable to create a differentiated magnetic rotating field. The smallest number of odd phases is three, hence it's popularity:-).
Re: phases
08/26/2008 2:22 PM
In a two phase system, the voltages are 90 degrees out of phase, not 180. A simple motor arrangement of four poles, connected to either two phase 3W (common neutral) or 2 phase 4W system produces the rotating magnetic field necessary for the motor's operation. See http://www.tpub.com/content/neets/14177/css/14177_88.htm
Re: phases
08/18/2008 11:06 AM
look at http://www.3phasepower.org/2phasesystems.htm. This should answer your question.
Re: phases
08/19/2008 7:40 AM
thanks a lot for that site
Good Answers: 15
Re: Two-Phase Machines and Four-Phase Power
08/30/2008 8:02 AM
Although i have never worked on polyphase machines i believe that some industrial power tool manufacturers make tools with their own inverter power supplies that work on a multiphase system.
Anonymous Poster (3); capblanc (1); Lendog (2); PWSlack (2)
