Previous in Forum: High Voltage Bushings   Next in Forum: Power Plant Alternator
UPS output from 110V (Domestic) to 230V (International).
08/18/2008 11:33 PM
I just want to ask if anybody knows how to convert a BACK-UPS or Surge Arrest of 110V to 230V output...
Good Answers: 230
Re: UPS output from 110V (Domestic) to 230V (International).
08/19/2008 12:31 AM
Hello kaizen
What you are hoping to do is not really cost-effective nor is it practical.
110V will be for 60Hz output.
230V will be for 50Hz output.
In the UPS/Surge arrester, (presumably for Computer or data process continuous supply), there is a large transformer, also a lot of complex electronics, on one or more printed wiring board/s.
To change the output voltage, it would be necessary to remove the following:
  1. Transformer
  2. Inverter circuit: all components
  3. Control circuit: all components
  4. Output socket/s.
  5. Other sundry parts, as required.
After the removal of all the above, you need to replace all above, with parts suitable for 230V 50Hz output, connect all, test, and ensure the UPS unit was satisfactory.
The cost of the replacement parts is far more costly that purchasing a new unit, with full Warranty, at present-day pricing.
You don't advise your Location or Country, (You may easily do this in your Profile, and it auto-updates through all your Topics and Posts).
Thus I am aware you may not have easy access to the money needed to purchase a new unit.
Nevertheless, a new unit will still be far cheaper than removing the unwanted parts, and replacing them so you have a 230V output.
Reply here, with
Kind Regards....
08/19/2008 1:27 AM
Hi Sparkstation
Thanks. I do agree with your comment. It is really a matter of redesigning your system from main supply input to stepping down your alternating current to rectifying and filtering your DC output voltage level then inverting to attain your desired AC supply (for online UPS) or from battery to inverter section to supply AC voltage.
I have units from Japan which is typically using 100 to 110VAC and I am thinking that I can just alter some part of the circuit particularly in the stabilized output circuit to provide output of 230VAC instead to act as an international UPS.
Thanks a lot!
08/20/2008 1:15 PM
the easy way would be a transformer
Register to Reply 3 comments
Anonymous Poster (1); kaizen (1); Sparkstation (1)
