Previous in Forum: Earthed Cables vs. Unearthed Cables   Next in Forum: AVR Circuit Diagram
Calculating the Cost of Heating with Oil or Electricity
08/21/2008 7:46 AM
How do I calculate the amount of water heated with a liter of diesel fuel (aka hetaing oil)? How do I calculate the amount of water heated by a kwh of electricity?
Re: calculating cost of heating with oil or electricity
08/21/2008 8:39 AM
This will help.
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
08/21/2008 8:48 AM
Other than theoretically, I think that would hugely depend on the water heaters used. Perhaps you could get a real world estimate from the energy star rating tag posted on each unit.
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
Re: Calculating the Cost of Heating with Oil or Electricity
08/22/2008 12:17 AM
The cost of Heating can be calculated as Under :
First calaculate the Heat Load By simple Heat transfer equtation :
Q= mXCPXDelta T ( 100X1.004(100-20) = 100X1.004X80 = 8032 k-cal/hr/863=9.3 KW. In India the Power cost is Rs 4 per KWH.
Hense total heating- cost- 37.22 Rs.
M- mass Of water In Lit or Kg
Cp- specifica Heat capacity Of water - 1.004 K-cal/Hr
Delta- T- Temp Diff Between- Higher Limit & lower limit
This will generate heat load in K-cal/Hr which can be converted by KWh by diving it by 863.
The cost of Electricity can be computed by multiplying the KWH rate to the total Heat load.
popat gawali.
BE mechanical-Pune Unieveristy
Register to Reply 3 comments
Anonymous Poster (1); Bricktop (1); PWSlack (1)
