Previous in Forum: Water Cooled Genset   Next in Forum: Torsion
Papua New Guinea - Member - Hubert O'oru Australia - Member - New Member Engineering Fields - Mechanical Engineering - New Member
Energy Balance
08/22/2008 1:25 AM
I am trying to work out how much energy is actually consumed from my steam generation and offcourse then I'll have to work on my efficiency and fuel consumption.
please help me out.
"Kind words can be short and easy to speak, but their echoes are truly endless." -- Mother Teresa
Re: Energy Balance
08/22/2008 3:47 AM
What help is wanted?
Please help the forum to offer advice by providing sufficient contextual information that gives clues as to what is needed.
Re: Energy Balance
08/23/2008 1:51 AM
ok I think I see what your looking for .
Try this!
BTU'S IN / BTU'S OUT
Take the BTU's of the material your using to generate steam then divide it by the amount of BTU's you are getting out of that process.
Some have high BTU's per ton and other lower with high sulphur which when burned turns to Microscpoic Mercury and ends up in streams.
After that you can subtract the amount of material used from what was gained to figure your waste.
You must consider if you using coal the Quality of it.
8,800 Btu/lbs.
0.50-0.75 lbs. SO2/mmBtu
This is low sulphur coal.
Some have high BTU's per ton and other lower with high sulphur which when burned turns to Microscpoic Mercury and ends up in streams. Pease do not consider adding trash like plastics to your engery source burning them releases too many TOXINS.
Re: Energy Balance
08/23/2008 5:04 AM
Why so complicated ?Isn't it just 539 cal/g?.-
Re: Energy Balance
08/24/2008 12:20 PM
You will find a wealth of informative handbooks at this site. Just Click on Handbook/Sourcebook --- then ---- Best Practices
The ones that you may be particularly interested are the"
Improving Steam System Performance - A Sourcebook for Industry
CIBO Energy Efficiency Handbook
Steam System Survey Guide
Re: Energy Balance
08/24/2008 12:42 PM
The original source of those above handbooks, plus more tips are located at:
http://www.eere.energy.gov/industry/bestpractices/techpubs_steam.html
Re: Energy Balance
08/24/2008 6:50 PM
Thanks so much for all the help....
i appreciate your outstanding help....
cheers
Register to Reply 6 comments
Anonymous Poster (2); dadw5boys (1); ferquiza (1); hubertooru (1); PWSlack (1)
