Previous in Forum: temperature rise Vs resistance   Next in Forum: Design of a new TEC
cable diameter
08/23/2008 5:48 AM
i want to calculate the diameter of 132kv xlpe cable
conductor diameter=34mm
conductor screen thickness 1.1mm
insulation thickness 13mm
insulation screen thickness 1mm
metalic sheath thickness 2.6mm
anti corrosion layer thickness 0.2mm
oversheath thickness 4.2/6mm
regards,
saadat ali
Good Answers: 140
Re: cable diameter
08/23/2008 11:31 AM
Are you joking?
Re: cable diameter
08/24/2008 3:45 PM
You have all the necessary information needed.
Try drawing a picture of your cable using the data you have supplied to get a clearer idea, then add up the thicknesses. Alternatively look at the data sheet for the cable overall diameter.
If all else fails, ask your secretary.
Re: cable diameter
08/24/2008 5:59 PM
add all but the conductor diameter together, multiply times 2, add conductor diameter, there's your answer.
Perfection is achieved, not when there is nothing left to add, but when there is nothing else to take away
Re: cable diameter
08/27/2008 3:10 PM
Use a pair of calipers
Register to Reply 4 comments
Graebeard (1); jack of all trades (1); North of 60 (1); Shawn_V_Elect (1)
