Previous in Forum: Kempe's Yearbook   Next in Forum: What is this thing?
9 comments
Papua New Guinea - Member - Hubert O'oru Australia - Member - New Member Engineering Fields - Mechanical Engineering - New Member
FK Compressor Centrifugal Pump
08/24/2008 9:56 PM
I had a recent breakdown on one of my main Centrifugal Sliding-vane type compressors. The problem that occurred was: the rotor blades that slide in-out of slots were chipped off and jammed the rotation of the main rotor. Inspections prior to corrective actions observed that there has been significant dust.dirt at inlet. I blame my intake filter bag which is old and has a couple of small holes.
I am address this issue to get any possible caused you might think had been the cause of the problem. I wish to let it be genreally discussed.
Regards.
"Kind words can be short and easy to speak, but their echoes are truly endless." -- Mother Teresa
Good Answers: 123
Re: FK Compressor Centrifugal Pump
08/24/2008 10:33 PM
This sounds similar to the rotary vane vacuum pumps used to prime fire engines. Also the same as the air motors used in air tools. Lubrication is essential for efficient operation. How is yours lubricated?
Bob
08/24/2008 10:51 PM
thank you bob c.
I have a seperate oil lube pump has supplied with the compressor(motor driven). The lube oil is pumped, filtered and distributed to 6 points of lubrication all through the operation of the equipment. Also prior to start-up, a 30 minutes lube is always done.
The compressor is connected directly to the Main Motor via a Coupling (with coupling pins). It sucks air from an air intake filter compartment that is located at the open enviroment outside. The working enviroment is dusty most of times. Intake filter bags filter dirt/dust/foreign object from entering suction line and damaging rotor and rotor blades.
Good Answers: 123
08/24/2008 10:55 PM
What material are the blades made of?
Bob
08/25/2008 1:50 AM
Blades are made of WOOd..there are 8 blades that slide in&out of slots when the rotor roates (driven by the motor).
Good Answers: 123
08/25/2008 7:44 AM
My guess is that those vanes are phenolic resin. It looks like a cloth saturated with some kind of resin. These are a consumable item. If you have trouble finding new vanes. you can try WWW.usplastics.com They have the product, and you could cut the sheets they sell into the vanes you need. You might need to round the vanes on the outboard ends, or angle cut them. Depending on the original design. Good luck.
Bob
08/25/2008 2:58 AM
I had the same problem with a car air conditioning compressor. The vanes were worn down so far, one came out of the slot and broke off the others. I determined that by measuring the intact end of one of the vanes, and the clearance at the widest opening reached as the compressor turned.
Good Answers: 67
08/26/2008 4:43 AM
Damaged and inefficient filters are one of the biggest cause of such failures because dust sticks to the vanes and cause unbalance leading to failure.
Location: USA Soviet Socialist Dictatorship of Cook County& Illinois
Good Answers: 15
08/26/2008 9:48 AM
Check wear on the vanes and the fit of the vanes into their slots. If the vane is too thin, it will cock in the slot and jam. similarily if they are too short, they will also lock. You didn't mention how old the vanes were or how long they were in service. I'd suggest that problem instead of particulates causing failure.
08/26/2008 9:10 PM
Thank you Morgan 23,
Yes, the these impeller blades were installed on November 2007 (9months ago). The intake filter bag was not replaced due to nil ex-stock. This equiment is a product supplied by FLSimdth Minerals Pty Ltd, and I am still awaiting for the new filter bags.
Yes, i'll take the advise on checking on the wear of vanes.
Now, my questions is: "is a common problem for this type of compressors?"
Hubert
Register to Reply 9 comments
bob c (3); hubertooru (3); Morgan 23 (1); pritam (1); RPalmer62 (1)
You might be interested in: Centrifugal Pumps, Rotor-Stator Mixers, Stepper Motors
