Previous in Forum: Hydraulic Fluid + Oxygen   Next in Forum: Fusion Energy
Solar Drying of Sunflower Seeds
08/25/2008 12:16 PM
What is the concept of solar dryer? How it works? Can a solar dryer be used for sunflower seeds to reduce moisture from 9% to 6%,if so How long does it take ? Does any company in INDIA has the technical capability to impliment?
Pathfinder Tags: solar drying of seeds
Re: SOLAR DRYING
08/25/2008 3:23 PM
If my Grandma can do you can two.
Tray with screen, screen holes two small for dried produce to fall through.
Place off the ground
Set in the sun
Wait till dry, measure moisture as desired.
No Problem. : -- ) Sun is bright in Arizona, why India?
Re: SOLAR DRYING
08/26/2008 10:55 AM
Dear
Thanks for your efforts in answering my query,Please read my edited query and try to give me the solution.
abimu
Engineering Fields - Instrumentation Engineering - New Member Hobbies - Fishing - New Member
Re: SOLAR DRYING
08/25/2008 4:09 PM
Hi, abimu,
Look out how housewives are drying their washings. Isn't it the opportunity to study of main concepts ? Then you'll be preared for Sun seed's experiments.
I'm supposing not only company either even multinational corporations but any person from over the world could implement this greeny concept for good.
caramba
Re: Solar Drying of Sunflower Seeds
08/27/2008 3:48 AM
Solar drying is used in the production of tea, a major export item from India and Sri Lanka.
It is also used in the separation of bulk sea salt, for home use and for export.
Register to Reply 4 comments
abimu (1); caramba (1); dbdwoods (1); PWSlack (1)
You might be interested in: Process Dryers , Compressed Air Dryers, Sample Dryers
