Previous in Forum: Can Bare Cooper Busbar Surfaces Be Cleaned/Polished?   Next in Forum: effect of cable capacitance on contactors
16 comments
Which Way to Connect Regulator Chip?
08/26/2008 12:14 AM
In converting my motorcycle to 12V, I built a positive 12V regulator for charging the battery for the stop and tail light, and a negative 12V for the headlight. This allowed me to use the other half-cycle from the magneto to get more voltage at low RPM. I used the circuit in the 1982 Fairchild linear book on page 2-64 for the negative regulator. The pin numbers are obviously wrong on the fixed output, but what about the high current one (which I built)? Other books were no help as they did not show pin numbers. The choice I made worked on the bench, so I took the motorcycle for a test ride. The headlight lit up for about 3 blocks, after which the chip burned up. Does the chip input go to the transistor, or does the output? Neither configuration makes sense to me, as you don't want high current flowing into the output.
S
Engineering Fields - Electrical Engineering - New Member United States - Member - New Member
Re: Which way to connect regulator chip?
08/26/2008 8:53 AM
Since it is doubtful that any other forum members are going to have the exact databook you used, you are going to have to provide more details on your circuit, and the wattage of your headlamp.
Tom
08/27/2008 2:50 AM
Well said Tom. We also need his final circuit(s) too......!
United Kingdom - Member - Hobbies - HAM Radio - G7TSP Engineering Fields - Electrical Engineering -
Re: Which Way to Connect Regulator Chip?
08/27/2008 3:16 AM
It sounds as if the regulator is only to provide a reference for the transisitor, maybe similar to a emitter follower circuit using a high power transistor. I'm assuming the power components are being mounted on suitable heatsinks? Unable to provide any more help, as the guys above have pointed out, too many variables.
08/27/2008 10:14 AM
How do you know the pins are wrong? The pin-out on negative regulators are different than the positive regulators in some cases. Here are the 78/79 family of linear regulators. ( I apologize for the cruddy graphics but I am trying to keep the bandwidth low.)
08/27/2008 8:47 PM
Thanks, you are correct about the connections.
08/27/2008 10:45 AM
Why dont you use a bridge rectifier on your magneto output then you can use the same polarity for all your lamps and charging.
Also your V regulators are probably a bit on the small side for the current to your lamps you could use them to bias some power transitors whiich can handle the current. Normaly regulation is cotrolled by a simple Zenner bridge tapped across the battery which stabilises the charge rate.
Good Answers: 97
08/27/2008 7:42 PM
GA, it is the method which works that gets the most attention
08/27/2008 8:46 PM
Hi Garth,
I tried to use a bridge, but couldn't locate the proper ground. Had it hooked to the ignition. They may be combined in a strange way.
The positive regulator chip also failed once before I added the 1K resistor (there is also a 0.1uF cap on the output pin). I have adequate heat sink for the power devices. The chips themselves shouldn't get hot, but are mounted on the same aluminum plate.
regards,
S
08/27/2008 9:55 PM
you circuit is no problem. if it fails, please check your input voltage, to insure it lower than 35 or 45V ( depend on manufacturer). otherwise, it will break out.
I was told, if you use motorcycle generator, it has very large voltage range and it will vey higher than 60v. so it will break out the 3 terminal device. so you hve to add a zener to keep it lower than 35v.
next, check output current to keep lewer than the output cutrrnt of the transistorl.
08/30/2008 11:42 PM
Hi,
You may be right about the voltage being too much. I have used your suggestion about a zener, but built a simpler circuit as I started out to do in the first place. I just have a power zener and two transistors in a Darlington arrangement. Took it for a test ride today, and so far so good. The heat sink gets a little hot, so I may make some improvements to that.
Thanks everybody for your suggestions.
S
08/28/2008 3:35 AM
I assume you have the tabs of the regulators insulated as the tab of the 7812 is GND and the tab of the 7912 is its input and therefore would be shorted to GND through the heatsink.
http://passthrough.fw-notify.net/download/684113/http://www.fairchildsemi.com/ds/LM/LM7805.pdf
Hope of some use.
Craig.
08/30/2008 11:33 PM
Hi,
The second link doesn't work. The first one is great, but doesn't answer the question because it doesn't have the high current application.
S
09/09/2008 3:20 AM
Apologies, I notice there are 2 URL there:
This was the one I intended:
09/09/2008 7:09 PM
Thanks,
I had it connected right, but it failed. I am finished with the project,
S
08/28/2008 2:40 AM
The idea has some merit I must agree.
If he does it, he should try and find some diodes with a very low loss, not normal silicon as they drop around 0.6 volt.....that can make a significant difference to lamp brightness when running "on the edge"!
I am sure someone here can recommend a diode type that has low loss and enough current handling to suit!
Good Answers: 15
08/30/2008 5:04 AM
Hi,
you cannot use a bridge rectifier if the magneto is pegged to frame on one side. If the ground termination can be lifted this would give you an isolated ac supply which you couñld then use a bridge rectifier and then connect the neg to chassis, which is the norm. if that is not possible then you could use a small 1:1 transformer to isolate the ac from ground.
Why not add a battery to the system? The difference to a modern system is that you will have to add a "dump" type regulator to stop overcharging the battery. You will need a 14V regulator that opens above that voltage dumping unused power to a resistance. This can be bought as a lump. they are used frequently in small generators.
Register to Reply 16 comments
Andy Germany (2); Brave Sir Robin (1); bwire (1); capblanc (1); cnpower (1); garth (1); Lemmy70 (3); StandardsGuy (5); tdesmit (1)
