Previous in Forum: Ash Heat Content   Next in Forum: A Temporary Sabbatical - Off To Iraq
Peltier TEC
08/26/2008 10:48 AM
My inquiry is about a Peltier Thermoelectric Cooler.
First of all I would like to give me information about the power consumption (watt) of a commercial TEC with dimensions 40 mm x 40 mm in order to create a temperature diffrential of say -25 Celsius (Ambient temp Ta=35, Tec Cold Temp Tc=10 ). Also I am going to use an Al heat sink to cool the hot side.
Secondly I am planning to design and make my own TEC for a domestic application with dimensions 200mm x 200mm in order to use it in the above temperature conditions. Which formula can be used in order to find the approximate power consumption (watt).
Thank you
zoumbro
Pathfinder Tags: Peltier TEC thermoelectric
Re: Peltier TEC
08/26/2008 3:23 PM
Best you start with a google search. This will give you links to the basics of Peltier devices as well as what is currently available on the market to purchase.
Good Answers: 94
Re: Peltier TEC
08/27/2008 4:35 AM
Greenweld show a 40 x 40mm peltier drawing 3.9A maximum. Your parameters would be much less than maximum but would depend on how efficiently you can sink the heat away.
Good Answers: 11
Re: Peltier TEC
08/27/2008 8:08 AM
You are also going to need a fan on the hot side heat sink. Convection alone will not properly cool the assembly.
Eric
Canada - Member - New Member
Good Answers: 11
Re: Peltier TEC
08/27/2008 9:13 AM
This free software from Melcor will help you in your analysis.
Good Answers: 12
Re: Peltier TEC
08/27/2008 10:03 AM
I would have to see the specs for your specific Peltier device to give you that info, but typical devices are about 5-10% efficient. That means at the high end of this range you will need 10 watts of power for one watt of cooling. Here are some basic units for doing your calculations;
1 Watt = 3.4129 BTU/hr
1 BTU is the amount of energy needed to change one pound of water by one degree Fahrenheit.
So, if what you are cooling is 5lbs and you want it cooled by 45 degree Fahrenheit (25C = 45F) in one hour you would need to provide 659.2 Watts of electricity.
Note - these calculations are all done on the high side of the efficiency range. Peltier devices have a sweet spot for efficiency and their effectiveness drops off if you push them past that.
-Doug
A robot must risk his neck for his brother man, and may not cop out when there's danger all about. - Isaac Hayes' First Law of Robotics
ca1ic0cat (1); drobertson (1); gigaconcept.com (1); jack of all trades (1); Nigh (1)
