Previous in Forum: Insulation testing of a 6.6 kV Generator   Next in Forum: QUESTION
how to- make /source a proximty switch?
08/27/2008 1:33 AM
I would like to operate some relays that are activated by the proximity of a hand or finger (with or without gloves) less than 1" to activate relay.. .. It's not desirable to use a mechanical button or switch. ..or photo.. or IR..
existing products?
simplest circuit?
few obvious options.. so I'm asking..
operating voltage of 12VDC
Good Answers: 230
Re: how to- make /source a proximty switch?
08/27/2008 2:53 AM
Hello JE in Chicago
Try a Capacitive Proximity Switch.
These are made with varying sensitivities, and are particularly suitable where a body part needs to be sensed without Optics, Infrared, or Mechanical Sensor type.
Refer here: http://www.globetron.com/capproxsw.html and http://www.globetron.com/capfilsen.html
Also refer here: http://sensors-transducers.globalspec.com/learnmore/sensors_transducers_detectors/proximity_presence_sensing/capacitive_proximity_sensors
And more here: http://www.ia.omron.com/product/48.html?gclid=CPKqu7-2rZUCFQv7agodpQVEkQ
These sensors are very robust, weather and waterproof etc, many operate from the standard Control Voltage of 24V DC, but you could check with suppliers for a 12 V DC unit, or alternatively, fit a small 12V DC to 24V DC Converter into your system.
Kind Regards....
08/27/2008 11:09 PM
There should be something on this site to do the job...or at least point you in the right direction....
http://www.lightcurtain.com/light_curtian-selection.html
Good Luck,
Roger
Re: how to- make /source a proximity switch?
08/28/2008 1:53 AM
Good Answers: 243
08/28/2008 10:22 AM
Sparky, randall, rcl:
Its a home run!
Nice job guys.
milo
08/28/2008 3:19 PM
is this set of relays on a machine? what kind? the fact that the operators are wearing gloves make me think of a machine tool of some kind. do you require operators hands clear of mechanism before starting? there are a number of great switches/sensors for this from balluff (www.balluff.com) banner (www.banner-engineering.com) STI http://www.sti.com/products/ and a host of others Allen bradley (www.ab.com) square d (www.squared.com) also have the switches and all else you will need for anti tiedown / hands clear operation. if you are looking for a "bargain" solution take a look at all of the above mentioned and then go hunting on EBAY where you will find all that you need and then some at pennies on the dollar good luck
God's greatest gift is the ability to learn.... and the worst curse is the ability to rationalize our behaviour
duffdr (1); Milo (1); Randall (1); rcl@rc-mfg.com (1); Sparkstation (1)
You might be interested in: Safety Gloves, Welding Gloves, Switch Boots
