Previous in Forum: Mechanical vary speed gear box failed, I want to know reasons, corrective act   Next in Forum: GASKET (ASME B16.20 and B16.21)
discharge
08/27/2008 10:34 AM
how to calcuate the discharge when the blower is at full load?
Re: discharge
08/27/2008 10:37 AM
Use the outlet pressure gauge and the blower performance curve.
Re: discharge
08/28/2008 1:11 AM
One method is to do a ducting traverse with a pitot-static tube (they even have digital ones these days so you don't need to even bother with calculation).
For an accurate number and with a round duct you should take at least 20 readings along two diameters - a rectangular duct between 16 and 64 readings. The duct diameter should be at least 30 times that of your pitot. Locate the pitot tube section providing 8-1/2 or more duct diameters upstream and 1-1/2 or more diameters down stream of Pitot tube free of elbows, size changes or obstructions; and if possible provide an egg-crate type of flow straightener 5 duct diameters upstream of Pitot tube.
A rougher estimate could be taken with a single pitot-tube reading in the center of the duct and factoring with 0.9 to obtain an average.
If you don't have this capability - I am sure a local HVAC contractor would be more than happy to help you out.
http://www.imeko.org/publications/wc-2003/PWC-2003-TC9-004.pdf
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
Re: discharge
09/05/2008 4:40 AM
What are you interested? Discharge flow or discharge pressure?
Look over to the next challenge
Anonymous Poster (1); PWSlack (1); user-deleted-1104 (1)
