Previous in Forum: RTD temperature probes   Next in Forum: heat transfer
Flow measurement using orifice plate
08/27/2008 4:23 PM
Can you please explain abaut the differential pressure tapings when an orifice plate is used as aprimary measuring element, ie; flange,corner,vena contracta and pipe tapings. How do we know where each of them are used and what is the distence between upstreem and down streem taping?
Pathfinder Tags: flow measurement
Re: Flow measurement using orifice plate
08/28/2008 12:59 AM
Hi ,
May be this will help
Flange Taps
Flange taps are holes drilled into a pair of flanges. Flange tap holes are not recommended when the pipe size is below 2 inches.
Pipe Taps
Pipe taps are located at 2 1/2 pipe diameters upstream and 8 diameters downstream from the orifice plate. Exact location of the taps is not critical. However, the effect of pipe roughness and dimensional inconsistencies can be severe. The uncertainty of measurement is 50 % greater with full flow taps than with taps close to the orifice. Pipe taps are not normally used unless it is required to install the orifice meter on a existing pipe, or other taps (such as radius taps or vena contracta taps) cannot be used.
Corner Taps
Corner taps are used when the pipe size is 2 inches or less.
Vena Contracta Taps
When an orifice plate is inserted into the flowline, it creates an increase in flow velocity and a decrease in pressure. The section downstream of an orifice bore shows an increase in velocity and decrease in a pressure at a point called a "vena contracta point." The location of the vena contracta point is between 0.35 to 0.85 of pipe diameters downstream of the plate, depending on the beta ratio and Reynolds number. Vena Contracta taps are located 1D upstream and at the Vena Contracta location downstream. Vena Contracta Taps are the optimum location for measurement accuracy. They are not used for pipes less than 6" in diameter.
Regards
Jose John
Egypt - Member - New Member
09/16/2008 6:44 AM
may I ask a question?
does the tapping points affect the reading (thats logical) but how it affects the reading? or in another way vena contarcta tapping is not like flange tappings so the drop in pressure at a same flow for the two types will be different, where can i find that effect in Bernoullis equation?
Register to Reply 2 comments
