Previous in Forum: TV PROBLEM   Next in Forum: Why are we stuck with Zeros and Ones?
output measuring
08/28/2008 2:32 AM
whats the difference between differential output and single ended output?
Good Answers: 230
Re: output measuring
08/28/2008 3:34 AM
Hello "Guest",
An electronic differential amplifier is a general form of amplifier, while a single-ended amplifier is made by grounding one input of a differential amplifier.
Learn more about them, right here: http://en.wikipedia.org/wiki/Differential_amplifier
Remember to improve your understanding, by also reading the hyperlinked webpages.
Kind Regards....
Engineering Fields - Instrumentation Engineering - New Member Hobbies - Fishing - New Member
08/28/2008 10:08 AM
I agreed with Spark's answer. But to be truth I was some confused then...
Is the question formulated properly? If Guest asked for differential input(s) --- represented scheme is ok.
Good Answers: 230
08/28/2008 4:56 PM
Hello caramba
is receiving increasing numbers of poorly formed or incorrect Questions, almost always from "Guest" ghost writers.
To answer those, I just try and interpret what I trust the Question asker intended, by "reading between the lines", and trust the train does not arrive while I'm still reading there.
Kind Regards....
08/29/2008 7:02 AM
Hello Sparkstation!
yes I see your train is running on me
best regards,
caramba
Good Answers: 230
10/28/2008 9:25 PM
Hello caramba
Your Avatar:
Are those chopsticks you are using in that picture?
Kind Regards....
10/23/2008 6:11 AM
Hello Sir ,
In Differencial O/P Driver , two o/p terminals for that digital communication will be available , ie Q and Inverted Q type .
For single ended o/p , One o/p terminal for the combination of I/P signals will be available .
caramba (2); sivaa (1); Sparkstation (3)
