Previous in Forum: Why are we stuck with Zeros and Ones?   Next in Forum: amit an engginear soul
CFL hack
08/29/2008 1:57 PM
So, I've got this project in mind. I want to build an LED array for my lantern style porchlights that jumps and flickers to look like a gas flame. That's not what I'm asking about - I'll figure that part out. What I'm wondering about is the innards of a CFL bulb. I understand that there are rectifiers which convert the AC to DC and a switched mode circuit that generates a high-ish frequency through a transformer to excite the gas in the bulb. What I'm thinking about is hacking into this to get the DC supply I'll need for my LED circuit - something in the 5- 15VDC range.
Has anyone tried this (and survived?) Does anyone have any details about the voltage levels inside the CFL circuit?
Pathfinder Tags: CFL hack
Re: CFL hack
08/29/2008 2:11 PM
bhankiii,
Did't they have beer signs for something like this, if not you may be on to something.
phoenix911
Re: CFL hack
08/30/2008 5:03 AM
Electroman might know...he like opening up chargers and stuff..(maybe PM him, he might be having a cat nap or on hol)
Prob' is it will be dense surface mount circuitry and difficult to work out what's what.
Re: CFL hack
08/30/2008 11:51 AM
I haven't actually done any measurements inside a working CFL, But I suspect they are rather similar to the fluorescent lamps used as backlights in laptop computers. These use about 300 Volts, so they have a tiny switching power supply to step up the battery voltage. Yes, they do use high frequency in order to be able to use a very small transformer.
On the other hand, for your project, you need to reduce the voltage, not increase it. It would certainly be possible to wind the transformer to produce a step-down instead of step-up, so give it a try!
Re: CFL hack
08/31/2008 1:37 PM
Yeah - I think that will be the plan - rewinding the transformer.
Re: CFL hack
09/03/2008 7:19 AM
taken from an NXP app note for a CFL chip.
The steady state operating point of a 13W PLC lamp is approximately: a lamp voltage of 75 V, a lamp current of 170mA and a lamp power of 13W.
http://www.google.com.au/search?hl=en&q=cfl+app+note&btnG=Search&meta=
first link,
that particular one is not the one I was looking for as it uses a chip, the simpler solution would be to use the more common 2 transistor version 5th link in the above search, the self oscillating one.
bear in mind that these circuits are not isolated .. it should be achievable without too much hassle though since the transformer needs rewinding anyway.
Re: CFL hack
09/03/2008 10:33 AM
Sweet - thanks for the link.
Register to Reply 6 comments
bhankiii (2); dkwarner (1); phoenix911 (1); stoney (1); user-deleted-1105 (1)
You might be interested in: Circuit Breakers, DC-DC Converter Chips, AC-DC Adapters
