Previous in Forum: current carrying capability   Next in Forum: air flow calculation
Need the MDP1400-S104's datasheet
08/30/2008 6:24 AM
Who can help me get a datasheet copy for thick film resistor networs MDP1400-S104?
Thank you!
WELCOME TO CHINA!
Pathfinder Tags: mdp1400
Re: Need the MDP1400-S104's datasheet
08/30/2008 6:32 PM
Try here I used to use this site at my old job. There are a few others, but I can't recall them right now.
Afterism (n) - A concise, clever statement you don't think of until too late.
09/01/2008 12:32 AM
Thanks for your reply.
WELCOME TO CHINA!
Good Answers: 46
08/31/2008 4:07 AM
Hello, I think the part is a Vishay part.
Here the link to there Document page.
This should help and good luck.
metalsmith's
Metal is the material, The forge is life, The anvil and hammer bring character and soul.
09/01/2008 12:33 AM
Thanks for your help.
But the MDP14 datasheet does not include the MDP1400' schematic.
It indicates the MDP1400's schematic is special.
So I still can not get this"special"schematic for MDP1400 from
the datasheet.
WELCOME TO CHINA!
Good Answers: 46
09/01/2008 1:49 AM
Hello, with the MFG info you maybe able to get the info on what the internal configuration is and/or from the mfg of the unit the part is used in.
Are you trying to repair a unit or reverse engineer a unit?
Or if you have several and just trying to figure out the internal configuration you can start by using a ohm meter and map the internal by measuring from the first pin to every other pin and noting the value. Then do each pin in order. Then you should be able to figure out the internal layout and value.
I don't know if this will help or not, I have used these methods in the past to to repair and make drawings for units I was not able to get prints for.
Good luck metalSmith's
09/01/2008 8:29 AM
Yes, I am trying to repair a unit.
It is a good method to figure out the internal
configuration by measuring.
Thank you very much.
Have a nice day!
WELCOME TO CHINA!
Register to Reply 6 comments
master of none (1); metalSmiths (2); michael.shang (3)
