Previous in Forum: 4-20ma   Next in Forum: Motor protection
Rick Webb Dairy Farmer
08/31/2008 3:17 PM
Can I run two 230 volt hand dryers using one 230 volt 3 phase tap. Each dryer is rated at 9.1 amps tap is rated at 25 amps. Rick Webb
Hobbies - HAM Radio - New Member United States - Member - New Member Hobbies - Hunting - New Member
Re: Rick Webb Dairy Farmer
08/31/2008 4:22 PM
Follow code for wherever you are. 230V 3 phase, where are you?
Tap?--Transformer tap?
Wire and size your fuses or breaker for 25A off the secondary or the tap--Is the Primary protected properly if this a transformer? AWG 10 is good for 30A, but don't exceed 25A on the fuse or breaker.
Air movers tend to run real close to their full load amp ratings, so I would count on the 9.1A. I would wire them so that they start independent of each other. The high inrush current of both may give you a tripping problem if they start simultaneously.
Those who believe in telekinetics, raise my hand --Kurt Vonnegut Jr.
09/01/2008 9:43 AM
The tap I am refering to is a power bar where 230 volt 3 phase is present then you insert the fuse /taps into to facilitate getting power. R.W.
