Previous in Forum: Lightning arresters for buildings   Next in Forum: Rick Webb Dairy Farmer
4-20ma
08/31/2008 2:22 PM
hi all
what is 4-20ma mean? is it fixed voltage supplied to the sensor and the change in sensor resistance will change the MA?
is it like this: sensor which i should give it fixed voltage to give me changable MA with the change of temprature or pressure ...etc?
will be great full for any info you could supply.
many thanks
Re: 4-20ma
08/31/2008 8:25 PM
Exactly, what you are thinking is correct. as a common 24 v dc applied at the transmitters cable, then a transducer changes its resistance according to the process variable. The 4-20 mA is measured at the suuply side.
Re: 4-20ma
09/01/2008 10:30 AM
The principle is as follows:
  • the transmitter modulates its output between 4 and 20mA according to the process variable
  • all the measurement and display devices are wired in series with the transmitter output signal, up to a maximum resistance on the loop; the maximum permissible resistance varies with the power supply voltage
  • All the items in the loop, being in series, 'see' exactly the same current.
Re: 4-20ma
09/02/2008 12:28 AM
Hi,
And the application for 4-20mA is to send Signals for SCADA equipments.
Regards,
N.Suresh
Anonymous Poster (1); k.dhana (1); PWSlack (1)
