Previous in Forum: Starter Motors   Next in Forum: Energy Conservation apparatus design
reed switch application
09/02/2008 4:39 AM
can anyone pls. explain me where a reed switch is been used in a coil winding machine and how does it function
"Life is what happens while you are busy making other plans."
Re: reed switch application
09/02/2008 4:50 AM
09/02/2008 5:10 AM
hello,
sorry i was not able to get u'r comments clearly.Could u pls. be little bit clear abt. what u want to say
09/03/2008 2:34 AM
If the position of the reed switch is fixed (most likely) then there is probably a magnet that passes within close proximity each time a coil is wound - in which case it's supplying pulses to a counter. That's just the most likely - it could also be used as part of the safety system - disabling moving parts until a cover is closed or something similar. It's just a switch, maybe a normally open, maybe a normally closed, that's actuated by a magnet or magnetic field. inside are two pieces of metal, touching if a n.c. or just barely seperated if it's a n.o. - one of the two pieces is attracted to a magnetic field that pulls it away fron the other contact, or pulls up against the other contact, again, depending on whether it's a normally open or normally closed.
Some days you're the pigeon, some days you're the statue.
Register to Reply 3 comments
amithwaikar (1); gadgetman (1); PWSlack (1)
