If you are asking the simple question of converting a known pressure measurement (psi/bar) into equivalent 'head' units then the equations are:
head [ft] = (p [psi] * 2.31)/SP
where SP = specific gravity of liquid
OR
head [m] = (p [bar] * 10.197)/SP
If you are asking for the more difficult problem of what pressure your pump will produce - that is a more involved calculation which takes a lot of other factors into account (mainly where your system curve intersects with your pump curve).
The pressure at any point in a liquid column can be caused by vertical column of the liquid due to its weight. The height of the liquid column at any point is called the static head and is expressed in height of liquid. The same head term is used to measure the kinetic energy created by the pump. The static head corresponding to any specific pressure is dependent upon the weight of the liquid.
Head (H) ft= Pressure (PSI) X 2.31/specific gravity
Or
Head (Met)= Pressure (bar) x 10.2/specific gravity
In case of water specific gravity is 1 and so
Head (ft) = Pressure(PSI) x 2.31
Look over to the next challenge
