Previous in Forum: Labels adhesive compatibility with Rubbers   Next in Forum: Weight of plate steel
stack height calculation
09/04/2008 10:41 PM
How do i calculate the tack height, based on the SOx emission from stack?
When i say that the burner type in boiler is of dual fuel type then what does it means?
  • Burning the the two fuels independently in burner or
  • Burning the two fuel simultaneuosly in buner
Re: stack height calculation
09/04/2008 11:43 PM
The "dual fuel type" means burning the two types of fuels at the same time and through the same fuel burner.
Calculation of the Stack height on the basis of the SOx measurement at ground level is generally performed with a dispersion formula, which also generally requires knowledge of the areal wind flow pattern.
EditorGBAnalysts - Give a boy fish and he will eat may be for a day, but teach him how to fish and he will eat everyday.
Location: South East of Las Vegas just far enough to see the lights but far enough to not hear the coins falling
09/05/2008 11:45 PM
Dear editor,
You are completely wrong.......Dual fuel means the burner is capable of burning two separate types of fuel. In most cases in the US that would be oil natural gas.
There are very few areas that allow the attempt to burn two types of fuel in the same burner at the same time.
I have burnt #6 oil and fish oil directly from a fish processing plant but it was not easy.
Your stack answer is good but not your dual fuel answer sorry.
Mike
Rule number one; Never ask a question unless you are prepared for an answer that you may not like.
10/28/2010 2:16 AM
Refer to your comment, i belief that a dual fuel burner use to burn two types of fuel separately. for example one fuel at one time either gas (Natural gas) or fuel like (Furnace oil,diesel,etc)
09/06/2008 2:46 AM
Hello,
1. Burning alternate fuels in same burner is a true Duel Fuel system
Should second fuel burn simultaneously with the mother ( First Choice) Fuel, it could be deemed as Co-Fuel, supporting Mother Fuel based handicaps to be over come.
We have one such Patent namely, Steam Stove, which works with Mother Fuel "Kerosene" and is co-fuelled by Water, carefully delivered to same burner to increase Thermal efficiency of fuel, for clean cooking and reduce cook timing as well as cost of Mother Fuel for given task of cooking compared to single Fuel only.
Thus to answer your querry, you can define the Boiler second Fuel as COMPLEMENTRY or Alternate Fuel to choice Mother Fuel as discribed above.
2. Measuring Stack Height from Emmision......what is the Objective?
Do you get Heaps of Disposable waste which needs to be stacked for letting off GHG emissions? Are You concerned with Stack height since Heat development within may be dangerous etc...?
Pl. clarify your circumstances and specic need oriented querry, then answer could be found to meet your need.
09/06/2008 3:55 AM
For all polluant dispersion problems contact member MBEYCHOK who is an expert.
Constant change is here to stay!
dovy (1); editorgbanalysts (1); Kishore Kaikini (1); miketheboilerguy (1); MZAFAR (1)
