Previous in Forum: What Does "CR4" Mean?   Next in Forum: Load Capacity for Air Conditioning
JP-8 Temperature
09/06/2008 2:22 PM
I would like to know the JP-8 fuel temperature at the underground pipe line, can anyone give me a good reply,
Thank you,
argeef1
Good Answers: 230
Re: JP-8 Temperature
09/07/2008 12:33 AM
Hello "Guest"
You need to advise the Location/Country of the particular underground pipeline.
We are not mindreaders
Reply here, with
Kind Regards....
09/07/2008 8:39 AM
Friends,
Thank you, anyway this is in Saudi Arabia at Prince Sultan Air Base, Al Kharj.
Regards,
argeef1
09/07/2008 11:53 AM
Why would the temp be higher than the earth it is stored in. Kerosene with additives does not have a chemical reaction I know of that creates heat.
09/08/2008 2:19 PM
Assume this is a storage tank/or adequately buried pipeline question.............. on info you supplied.
The temp will be the delivered temp less the ground temp draw down.... if not exposed to sun/air ambient temp unless storage is not covered with a minimum of four feet of earth.
If the delivery system from the tank is linear extensive there will be substantive heat gain in the delivered product...subject to time/atmosphere exposure.
If metered at the tank.......or metered at the point of delivery there may be an unacceptable volumetric quantity change between the two. Temp correction required.
MR. GUY
If you are looking for a positive answer..it's YUP......
Anonymous Poster (1); dadw5boys (1); Mr. Guy (1); Sparkstation (1)
