Previous in Forum: Bus Fault in PLC   Next in Forum: Marine Cables
9 comments
ELCB and MCCB
09/07/2008 4:48 AM
Need schematic diagram of ELCB and RCCB,which showing the fundamental functioning difference
ELECTRICAL ENGINEER
New Zealand - Member - Kiwi
Good Answers: 29
Re: ELCB and MCCB
09/07/2008 4:33 PM
Please do not post homework questions here.
paulusgnome
Re: ELCB and MCCB
09/08/2008 3:12 AM
wow, sharp and spicy answer like an arrow .....
Re: ELCB and MCCB
09/08/2008 1:24 AM
MCCB have thermal overload which provide tripping commend if temp. increasde with increase in current(load).Normally in amp(2amp to 1000 amp)
ELCB check leakage current between earth & nutral , it is normally in miliamps (30mamp or 100 mamp).
Re: ELCB and MCCB
09/08/2008 3:21 AM
MCCB = Molded Case Circuit Breaker
additional idea for Guest idea,
MCCB used to protect circuit from short circuit and overload. MCCB can be modified with relay 50/51. this 50/51 relay get input from CT, and ouput from this CT can trip MCCB (of course, we must add shunt trip in this MCCB).
for ELCB, as long as i know ELCB used in 1 phase. for three phase, we use Zct. Secondary cable from Zct goes to 50G relay. and then 50G relay makes contactor trip. or 50G relay makes MCCB (complete with shunt trip) trip.
Zct is CT with 1 hole. all of three cables(R,C,T) goes through this 1 hole.
Engineering Fields - Power Engineering - Projects Engineer
Re: ELCB and MCCB
09/08/2008 10:04 AM
MCCB are curent limiting devices which function in two ways
1) relay tripping for short circuits
2) thermal tripping for overloads
ELCB are monitering the earthleakage currents and in an evant of earth current flowing it will trip they come in sensitivity of 30ma and 60 Etc
Normally recommended in areas of high earth resistance where the MCCB will delay in tripping.
A wise person will understand more from a Foolish question than what a Fool will understand from a Wise Answer
Good Answers: 42
Re: ELCB and MCCB
09/08/2008 11:36 PM
Dear Friend ,
This is a basic question which has answers in the net if you surf a little in google.Please read the following links and come out with doubts if you have any one. In CR4 this was discussed many times earlier. Take a little pain to read the earlier threads. it will help you in understanding the subject if you decide.
http://www.allinterview.com/showanswers/61375.html
http://en.wikipedia.org/wiki/Earth_leakage_circuit_breaker
http://in.answers.yahoo.com/question/index?qid=20080308001048AAgQjG2
Re: ELCB and MCCB
09/08/2008 11:43 PM
Dear Friend
some of the post already mention the main differences but you have asked a schematic diagram for which long time i am searching too. those have stated it is a home work, in fact they themselves in quest.
manirul
Re: ELCB and MCCB
06/05/2009 4:41 PM
elcb meains earth tripped good safety equipment
mccb meains short circuit &over load tripped
Re: ELCB and MCCB
10/14/2024 4:02 AM
Internet search engines can provide this. So can telephone calls to the equipment manufacturers.
Register to Reply 9 comments
Anonymous Poster (2); elect-ok (2); manirul (1); Paulusgnome (1); PWSlack (1); SAK (1); V.I.Abraham (1)
