Previous in Forum: pls explain CuZn39 Pb3 F50 coating   Next in Forum: hp calculation for eccentric lift
cfm
09/09/2008 6:09 AM
how can calculate air flow in cfm when pipe size (mm) and air pressure known in bar
pl. give farmula
Re: cfm
09/09/2008 6:28 AM
Hint: what is the velocity in the pipe?
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
Re: cfm
09/09/2008 8:48 AM
The formula to calculate air flow in Cubic Feet per Minute (CFM), determine the flow velocity in feet per minute, then multiply this figure by the duct cross sectional area.
Air Flow in CFM (Q) = Flow Velocity in Feet Per Minute (V) x Duct Cross Sectional Area (A)
Look over to the next challenge
